Post by cobber on Jun 9, 2014 17:58:44 GMT 10
Cobber, the description in the advertisement states "wrap around front window" but the photo is not showing that version. Is the photo really representative of this new Cuniform aluminium, do you think?
I'm sure you remember this discussion...? It only happened five years ago (on this thread here)!
The comment from Franklin1 is in reference to a 1959 advertisement for Viscount which refers to 'Cuniform', a form of aluminium cladding. I've been trying to work out what 'cuniform' was, but can't find any references to it in relation to aluminium sheet. The only references to 'cuniform' (sometimes 'cuneiform') are in relation to Babylonian wrtiting, etc, as in 'cuniform tablets'. In some respects the stippled surface of aluminium cladding looks not unlike the surface of cuniform writing on Babylonian clay tablets, so I'm wondering if Viscount were using 'cuniform' to refer to stippled aluminium sheeting? Have either of you - or anyone else who reads this - worked out what 'cuniform aluminium' was or seen other references to it?
I have been meaning to update that post for some time.
It's basically a form of annealing as you can see by the following paper I wrote some time ago
I'd like seeshell to explain the process in layman terms for those of you who can't grasp the concept
The cuniform-like MnO2 particles were first successfully synthesized with dodecylbenzenesulfonic acid (DBSA) as surfactant in aqueous solution. The samples were characterized by transmission electron microscopy (TEM), X-ray diffraction (XRD) and infrared spectroscopy (IR). The possible mechanisms of the shape evolution for the formation of MnO2 samples were discussed.
