Post by shesgotthelook on Apr 7, 2019 20:44:16 GMT 10
Post by shesgotthelook on Apr 7, 2019 20:50:07 GMT 10
Post by Roehm3108 on Apr 8, 2019 6:39:17 GMT 10
A good scrub down, a lick of paint, a few nails and phillips head screws and she'll be as good as new!!! I see another roll of Glad used up too!!!
Post by Mustang on Apr 8, 2019 9:12:30 GMT 10
Lucky van!!!! sitting all those years, then ending up with you, funny how they take the wheels off, now look at it after a day already with Whitewalls!!!
Post by shesgotthelook on Apr 8, 2019 11:44:32 GMT 10
ha ha Mustang. One is the spare from my EJ & the other is the spare from a Viscount caravan. While we are talking tyres, I'm on the hunt for a pair of 13" Holden rims within cooee of Echuca Vic.
Post by shesgotthelook on Apr 29, 2019 17:02:20 GMT 10
Post by redmr2red on May 1, 2019 17:49:33 GMT 10
It's almost the same as my 1945 Wayfarer (built by Globe) that I'm restoring now.
Post by shesgotthelook on May 4, 2019 9:19:42 GMT 10
Post by Roehm3108 on May 4, 2019 9:34:28 GMT 10
Hi SGTL. I got my Rowvan rubber from Clark Rubber, so you're correct there. You need to know what size openings you want. They do have online shopping now, so why not go with the times?
Post by grandad on May 4, 2019 9:42:31 GMT 10
Or take a trip to Bendigo. We have one up near Spotlight.
Post by redmr2red on May 5, 2019 17:07:09 GMT 10
Yes that's the right stuff from ebay. It's two parts - the rubber that goes around the glass, and the locking bead when the rubber is fitted to the van. I bought Clark rubber stuff that didn't have the locking strip and it was impossible to fit. I rang a windscreen fitter for advice and he supplied and fitted for $30 a window.
I had the fitter install the locking bead to the inside so from the outside it looks the same as the rubber was fitted in 1954.
Post by shesgotthelook on May 16, 2019 17:54:09 GMT 10
Post by Mustang on May 16, 2019 18:29:58 GMT 10
Bloody Hell, "bit by bit", I would say big chunks by big chunks!!!!
Post by shesgotthelook on May 26, 2019 19:40:03 GMT 10
hughdeany
Member is Online
Post by hughdeany on May 26, 2019 21:21:50 GMT 10
Hi Sgtl, I remember seeing Globetrotters in the distant past that had that mottled effect. I always thought someone just flicked paint on the doors! Cheers Hughdeany
Post by grandad on May 27, 2019 9:24:33 GMT 10
I've seen a very similar effect on furniture years ago. Different colour acrylic paints were literally splattered on randomly. What I remember of the technique was a scrub brush, like a heavy duty hair brush was dipped in a colour and then something akin to an old wooden ruler or paint stirrer was dragged across the bristles in such a way that tiny droplets were flung onto whatever colour basecoat was used.
Also, I did a custom paint job on a bicycle a long time ago using different colour spray cans held much further away than you would normally so that drops landed on the surface rather than the even fan one would normally aim for.
I suspect in a factory such as the one that made Globes, they may have adopted a similar technique using a spray gun.
Jim
Post by murray on May 27, 2019 15:56:27 GMT 10
Hi Sgtl, I remember seeing Globetrotters in the distant past that had that mottled effect. I always thought someone just flicked paint on the doors! Cheers Hughdeany The internals on a lot of the sunliners have the same mottled painted effect cool boy names yahoo answers
Post by aussieute on May 27, 2019 16:09:40 GMT 10
It could be a spray gun with straight paint in it it gives a splatter effect I used to paint the Holden ute tubs with very little thinners in it causing the paint to string with the gun set to narrow jet the Holden ute used to have a tan background with black and red stringing through it cheers chris
Post by Johnny & Annie on May 28, 2019 8:51:28 GMT 10
According to a house painter, I asked about it, it was a paint they used to call "chicken shit". Was purchased as such and sprayed on.
Post by Rattles on May 28, 2019 17:54:11 GMT 10
Post by shesgotthelook on May 30, 2019 15:38:43 GMT 10
More window rubber woes. The small galley window & 9mm marine ply. I grabbed a sample of the biggest piece they had at Clark rubber but it's still too narrow & there is no way it will turn around the corners either. My builder man Noel is thinking of making a frame to hold it on the inside but that still doesn't solve the outside. I have been to C Rubber, a windscreen shop & a glass suppliers, none have got a solution for me.
hughdeany
Member is Online
Post by hughdeany on May 30, 2019 17:01:42 GMT 10
Hi Sgtl, I believe that ecscavator window replacements might be able to supply or even fit for you. Cheers Hughdeany
Post by shesgotthelook on May 30, 2019 17:32:22 GMT 10
Do you have a link Hughdeany?
hughdeany
Member is Online
Post by hughdeany on May 30, 2019 21:16:19 GMT 10
No sorry,I had one done a few years ago and got the local guy to do it. Maybe try the stock agent who might know of someone in your area. Cheers Hughdeany
Post by aussieute on May 31, 2019 18:17:49 GMT 10
You could try oz auto rubbers in Hallam Vic there website has all the different sizes I found Clark rubber was too small to turn the corners on my Jennison and they will post hope this helps cheers chris
