Post by Observatory on Dec 18, 2014 14:26:57 GMT 10
More alignment correcting: - placed a 3 inch long strip of this 4mm Tas. oak under the back cladding (just below the wrap around); to get the cladding to kink to the left (looking from rear). It worked
Post by Observatory on Dec 19, 2014 11:38:19 GMT 10
Router fun continues: - Trusty horseshoe file in action.
- Test fit for window frame.
Post by Observatory on Dec 23, 2014 12:01:54 GMT 10
Making the guard corners out of some 24mm thick hardwood scraps. - using the guard cladding as a template
- used an angle grinder with flap wheel to get the concave.
dayno
Post by dayno on Dec 24, 2014 17:56:11 GMT 10
Well I must say I'm impressed with the reno observatory. I shall be keeping an eye on this thread for more hints and tips. Good work mate. It's very inspiring for my part Reno on my 65 Caravelle.
Post by Observatory on Dec 29, 2014 10:09:16 GMT 10
Thanks dayno.... I'm just having a go (and making plenty of mistakes along the way). Learnt a lot so far and ain't out of the woods yet. Cheers, Pete
Post by Observatory on Dec 31, 2014 9:54:44 GMT 10
Prep. and more prep... cleaning up the corner moulds.. - before and after
- EDIT 2/1/15 ..and prepped corner moulds and window trims
Post by Observatory on Jan 5, 2015 14:27:39 GMT 10
Post by Observatory on Jan 6, 2015 13:48:40 GMT 10
A couple of coats of Antique White USA low sheen interior and pretty close to getting the window trims in. - used Sika fine surface filler for the panel seams
Post by mibosa on Jan 6, 2015 14:28:08 GMT 10
Hi Pete, did you apply the paint with roller, spray gun or some other method? Any primer, or was your paint designed for both? Regards, Bob
Post by Observatory on Jan 6, 2015 14:48:23 GMT 10
Hey Bob, - Cut in with a 1 inch brush
- Rolled with a 75mm 10mm Nap roller no primer - yes paint designed for both (light sand with 240 grit in between coats)
I originally started painting with an exterior paint (for durability) but stuffed up with the colour pigment and got biege
Cheers, Pete
Post by mibosa on Jan 6, 2015 15:01:34 GMT 10
Okay Pete, thanks for that info. At the rate your are progressing I look forward to seeing your van in Adelaide in February, asking a few questions and getting a few ideas!!! Regards, Bob.
Post by Observatory on Jan 7, 2015 11:24:17 GMT 10
- Window trims screwed in with good outer facings for new wrap arounds.
- Exterior walls now have a clear coat - 1 litre of varnish. (thanks Gordon I'll have to write you another cheque )
Post by Observatory on Jan 9, 2015 14:30:18 GMT 10
Prepping and painting...
Post by cobber on Jan 9, 2015 15:49:00 GMT 10
Pete, can you slow down a bit mate ? you're making me feel old You seem to get more work done in a day than I do in a week, she's looking good though Cobber.
Post by DC3Td on Jan 9, 2015 16:25:48 GMT 10
Gday Pete.Judging by how it looks up to now you might have to change the name to Conservatory. gordon
Post by Observatory on Jan 13, 2015 13:34:06 GMT 10
Thanks Gordon, thanks Cobber I'm trying to go slower - I went slow screwing in the slot head screws which take time - Screwed in the splashback over the sink and the metal track for the sliding stove cover.
- Used 4 scrap ply pieces to screw the metal track into + finished nailing in the sink from outside with 20mm flat head nails; used the old wall panels as templates to find the nailing points.
Post by Observatory on Jan 14, 2015 14:14:00 GMT 10
- Reinstating the clearance lights... EDIT: 4/5/15 also added dedicated earths from the front, side marker lamps - back to the junction plug under the bench seat. Reason for this: the added damp course over the Z-rails - will stop the original earth traveling through the side cladding and up to the front, side marker lamps.
- Diagram I did back in August '14
Post by akeepsake on Jan 14, 2015 15:40:04 GMT 10
Love a good bit of wiring ! What a great Restoration you are achieving Pete. No shortcuts here ! Keep up the good work it's a credit to you! Cheers Andrew
Post by Observatory on Jan 15, 2015 11:34:16 GMT 10
Thanks Andrew will do. Rear lights now working. - rear shelf laminate and trim in.
Post by DC3Td on Jan 15, 2015 16:12:44 GMT 10
Gday Pete.Always good to have a rear shelf to rest the beer on.Another way of useing as a spirit level too. gordon
Post by Observatory on Jan 16, 2015 8:10:48 GMT 10
Cheers Gordon. Your idea is certain to be implemented. Is there anything beer cannot do? And in the words of Homer J. Simpson: "to alcohol! The cause of - and solution to - all of life's problems" Pete DC lighting reinstated.
Post by Observatory on Jan 20, 2015 9:56:18 GMT 10
240 volt cabling reinstated (thanks to German Chris for checking and signing off) - 3 times GPO + 3 times lights
- All 240 volt replaced with new 25 Amp cable
Post by Observatory on Jan 21, 2015 9:49:22 GMT 10
Cladding repairs - filling some (jaffa sized) holes left by electrolysis with chassis. - Polyester resin over fibreglass mat (applied on the inner side of cladding)
- Light sand with 120 grit (outer side )
Post by Observatory on Jan 22, 2015 12:17:47 GMT 10
Post by Observatory on Jan 27, 2015 10:52:58 GMT 10
