pippa
Post by pippa on Feb 10, 2017 5:46:36 GMT 10
Wow fantastic work!!!! and thanks for the great photos and description of each task.
Post by strugglebrook on Feb 11, 2017 9:02:01 GMT 10
Dear Mr and Mrs Cac, Now that the Super Sun Liner is on i`ts maiden voyage it would be nice if you were to put up photos as it travels along the eastern seaboard and beyond. Something for us working mice as we run around the mouse wheel to aspire too.
Struggle Brook.
Post by 53vicky on Mar 29, 2017 15:48:00 GMT 10
Hi Sutcac Just wondering if you got all your cupboard handles new or original i am a few short and what I have a poor cheers ted
Post by sutcac on Apr 4, 2017 15:34:07 GMT 10
Hi Ted.Used originals.They are are a bit ordinary up close.....slight pitting but do the job.....I just buffed 'em up with mop. Ihave some you can have but wont be home till May
Post by sutcac on Apr 4, 2017 15:43:49 GMT 10
OK
Post by sutcac on Apr 4, 2017 15:54:31 GMT 10
OK Who likes a guessing game? How heavy is our 16'Sunliner? Fully rebuilt with new 12mm ply floor All new furniture 90l fridge 100w battery 100 l watertank (full) Orig chassis new axle/springs etc Loaded with all our food /clothes /shoes/bedding For 3 month tour.
Good luck!!
Oooops....forgot to say that they were about 680 kg from factory if I remember correctly.
Post by Koala on Apr 4, 2017 16:21:18 GMT 10
1250kg or thereabout is my guess.
Post by Warrenk on Apr 4, 2017 16:47:10 GMT 10
A clue, what was the weight when it was registered? I am guessing about 850kg The rule of thumb for payload for a single axle caravan is 300kg, and from what I have read that normally balloons out to 400kg plus. Have to agree with Koala's figure of 1250 kg.
Warren
Post by sutcac on Apr 4, 2017 16:50:59 GMT 10
Wasn't weighed for rego.Self assessed ar 730 kg..........but probably closer to 900kg in reality.
Post by margra on Apr 4, 2017 18:08:07 GMT 10
Usually in Queensland the allowed extra weight for water clothes etc is 300kg and this added to the tare weight is what it should be registered at. There is no change in rego price until you go over 1.02t and you get to run a small number plate. Self assesmant is usually for box trailers ONLY with no brakes and a gross weight of 750kg. The BIG problem is if something goes wrong and the van is weighed then all sorts of overloading problems arise which could mean loss of insurance and maybe a court appearence. A rodworthy check is also required on trailers over 750kg for rego or sale.For the price that does not change it is better to be legal than to try to save a very small amount of money and to do things legal. A lot better in the long run because near enough is not good enough with the technology that enforcement people have these days. The weights also have to be stamped on the drawbar if no compliance plate fitted which with old vans is usually the case.I myself like to drive down the road knowing that I am legal and if something does go wrong I have covered my own bum and the bum of others if any and not flying by the seat of my pants. Self assesment might fool the counter staff at rego points but it will not fool the people that are on road enforcement. Sorry Sutcat old habits die hard lol
Graham
Post by 53vicky on Apr 4, 2017 19:24:35 GMT 10
Hi Sutcac That would be much appreciated but I am happy to buy them as mine are either missing or broken but some are probably similar condition to your so hopefully will clean up.....May is fine as I am just doing some painting at present. Cheers ted
Post by margra on Apr 6, 2017 19:20:15 GMT 10
Another thing about self assesment is as the owner has to sign on the dotted line. It is to be noted that the form is an official bit of paperwork that says all is true and correct. Aything not correct like weights is false and misleading and is classed as giving the rego people false and misleading information which carries very heavy penalties but the main worry is that the caravan becomes UNREGISTERED as it is not what is on the application for registration paperwork.. Something to consider very carefully as to what one does.
Graham
Post by Roehm3108 on Apr 7, 2017 8:41:58 GMT 10
Hey sutcac, I reckon your rig will come in well over the tonne, if you put it on a weighbridge, in which case, like the others already said, it's dicey!!
Post by strugglebrook on Apr 7, 2017 16:22:27 GMT 10
Let me see, 680KG bare van,200kg of mod cons, 100kg of clothes , 100 kg of Mrs Sutcacs antiques/dinner sets ect and 125kg for Mr Sutcacs wallet. lets see ,that`s 1205 kg. Sugest moving the wallet up the front for better towing.
JD.
Post by sutcac on Apr 9, 2017 14:42:54 GMT 10
Hhmmmmm......van came in at 1420kg.!!!!!! Had to redistribute some weight to get towball weight up from 120kg to 140kg. Tows beautifully at that.
Post by Koala on Apr 9, 2017 15:09:21 GMT 10
Struth, that is heavy. I would be concerned about what wheel bearings and rims you are running. Early holden rims will likely crack like mine did. Pleased you took JD's advice and moved your wallett:))
Post by margra on Apr 9, 2017 15:52:19 GMT 10
Bloody hell Sutcat that bad mate, would say that the van is not what was stated on the initial registration so the van is definitely unregistered. Hope all is good for you whilst traveling.
Graham
Post by Roehm3108 on Apr 9, 2017 17:18:40 GMT 10
Hey koala, sutcac didn't move his wallet, the weighbridge was free!!! The final weight doesn't surprise me one bit, when you consider what you did to that van sutcac. How many litres of paint is on the van? Even at the same weight as water (and paint would be heavier) there's probably an extra 100 kg added by paint and fibreglass filler alone. You've increased you water weight by double! It soon adds up - a good lesson for us all!!!
Post by strugglebrook on Apr 10, 2017 8:43:01 GMT 10
Mr Koala, I think I owe Mr Sutcac an apology , Wallet a lot heavier than I thought. Also Mrs Sutcac has been on the road for a while now, thats a lot of antique and second hand stores passed (not)her contribution to this conundrum should be not underestermated.
JD.
