Post by phoenixrising61 on Apr 22, 2015 13:57:17 GMT 10
Hi all, First posting here and it's a little complicated and technical so please bear with me. Btw, while I have over 30 years in the car repair industry so I only know a bit about caravans. We have opted to do a renovation of this van, not a restoration as there are some modern items we wish to incorporate.
To set the scene: our 1966 Franklin Premier 14 ft is a single axle job with no brakes fitted. It has a drop axle which I believe to be of 3 inches. It also has the slip-type 7 leaf springs under the axle. It also has 13 inch rims and we can only assume they are Holden rims, both of which need replacing due to rust. There is perhaps only 3 fingers width clearance from the top of the tyre to the wheel-arch, with an empty van. The van appears to sit at a good height.
I have concluded that a mechanical brake system would be preferable but I am concerned about the drop axle and fitting backing plates/drums to it. The axle tube seems quite substantial, about 3 inches diameter. and I had thoughts of moving the leaf springs to the top of the axle to gain some more clearance in the wheel arch.
So the questions are, is any of this feasible?
Would the van finish being too high up with springs on top?
Would I need to replace the axle for fitting backing plates/drums on to a more modern axle? (New drop axles are either 2 or 4 inches drop. The shorter drop would raise the body height by an inch I believe, giving an extra inch in the wheel arch)
Should we go to 14 inch rims for the load rating (couldn't do that with the current arrangement)?
Is hydraulic better than mechanical breaking? (Electric will not be required as it will not be more than 1400 kgs, and besides, I don't want a controller in the car, just a personal preference)
Sorry for the length of this post but as I said it's a bit complicated and messy. Look forward to any advice, tips, links whatever you have to offer.
Thanks,
Andrew
Thanks,
Andrew
