Post by yellowuki on Oct 6, 2020 12:21:12 GMT 10
Hi All
As most of you know I have recently become custodian of Arthur and Pat's Joker2. The van is a little worse for wear though nothing some running repairs won't fix. I have opted to create a thread here with some updates, though Don Ricardo did mention perhaps creating a down history lanethread to capture some of the amazing history this van has.
The first two priorities are; weather proofing and braking.
As is well documented in other areas of this forum, Arthur built this van with a very well engineered vacuum brake set up. I have agonised over this and sadly, time has taken its toll and it's no longer practical to be using. I am currently going to great effort and expense to have a new axle fabricated to accommodate electric brakes while maintaining the original wheels. I had always thought the Joker had Vanguard wheels same as the original tow car, but not the case. The wheels are of unknown origin, they're 14' with a large stud pattern and large wheel studs. Tabs have been welded on to the rims to accommodate the Vanguard centre caps, modifications have also been made to the centre caps to accommodate the valve as it sits a lot closer to the cap than it would if it were on a 16" Vanguard wheel.
The end result of this particular project will be new axle, bearing brakes on original wheels. The vacuum tanks will remain in place so visually this modification will make no change.
hosting.photobucket.com/images/ac246/John_Bourke/axle.jpg?width=285&height=175&fit=bounds&crop=fill
hosting.photobucket.com/images/ac246/John_Bourke/brakes.jpg?width=285&height=175&fit=bounds&crop=fill
Roof hatches X 2. Probably somewhat unique for 1957, the Joker was built with two roof hatches. The are made of very light tin and Masonite. Time has not been kind and I'm amazed they made the trip home without flying off. These have been reconstructed using 12 ply and should be sound for a good number of years yet.
hosting.photobucket.com/images/ac246/John_Bourke/hatch1.jpg?width=285&height=175&fit=bounds&crop=fill
hosting.photobucket.com/images/ac246/John_Bourke/hatch2.jpg?width=285&height=175&fit=bounds&crop=fill
hosting.photobucket.com/images/ac246/John_Bourke/hatch3.jpg?width=285&height=175&fit=bounds&crop=fill
