Post by atouchofglass on Feb 10, 2008 6:10:44 GMT 10
Greetings all Quick question for all those Olympic owners out there. When I purchased my Riviera the electrics were in less than original order. Read only half the electrics were conected. Does anyone out there have a diagram of the electics?? That is a long shot so the other question is .. What is above the sink....... what is above the table .....and what is above the rear window? ? Cause in mine it is just holes. .... ex electrics, former sumthin eruthers.... All help greatly appreciated... Atog
Post by akallabeth on Feb 10, 2008 8:07:48 GMT 10
Hi Atog, Above my riveria's table i have a light, over the rear bed there is a light, over the sink (a little to the rear) is a powerpoint (with one on the oppisite side on the wall). The rear sink powerpoint is mounted in the underside of the upper storage area.... I also have a powerpoint at the front of the kitchen bench (wall mount). Sorry i dont have pics.... Not sure if all that is original....... but its what mine has. Good luck with the electrics!!
Post by Franklin1 on Feb 10, 2008 20:56:13 GMT 10
Post by atouchofglass on Feb 11, 2008 5:53:42 GMT 10
Thanks Guys Akallabeth - That does answer the question/questions. Franklin1 - The photos are excellent for what I am looking for. Strange thing- when I first started looking on this site I searched all the threads looking for Olympic threads and never found the ones you pulled up for me . Must be getting see nil in my old age ;D Thanks again Atog
Post by bobshannon on Feb 11, 2008 8:02:15 GMT 10
Hi, From my memory of working on a couple of Olympics the whole of the 240v and the 12v wiring was done in white only wiring. If yours is of that period I would be talking to an electrician before hooking up any 240 wiring. Today, all white is unacceptable (Australian Standard). An electrician may advise (with good reason) all the 240v wiring be replaced as some also had dual 12v/240v light fittings where it may be easily mixed up. And fit a safety switch just for your own piece of mind!! By the way, the Olympic range would be right up there as the best vans manufactured in Australia. If looked after they will last forever. Bob
Post by atouchofglass on Feb 11, 2008 21:43:13 GMT 10
Thanks Bobshannon Yes your right the wiring was done in white and with an exposed earth. There will be a circuit breaker for the lights, fridge and power points.... just to be sure. Currently I am working for an electrical and air conditioning company. So I have been able to get their short lengths of new wire to rewire my van. Short lengths to them is less than 3.5 metres. FREE ....Can't beat that for a price. Struck a snag in trying to remove the old wiring that runs between the ceiling and roof of my van ceiling. It goes from the power plug on one side of the van to switches near the door on the other side. .....the wiring is stuck fast in place .... so it seems that I will be running it around the front instead. Arrh the joys of renovations. ..... anyone else had similar issues. Atog
