Post by Roehm3108 on Apr 14, 2019 21:13:35 GMT 10
Hi Folks I seem to be having trouble sourcing used pressed metal tiles up here, which I would like to used in Cino Vardo. They look similar to this (example only!): Because I only want to have them as a splashback for the sink area (about 6 inches high), I would like a small pattern, so that the pattern doesn't need to be cut up. If anyone can help, please let me know ASAP, perhaps also with a pic. Thanks Ray
Post by shesgotthelook on Apr 15, 2019 8:17:21 GMT 10
Post by Roehm3108 on Apr 15, 2019 10:19:23 GMT 10
Hi SGTL. Yes, I've seen that site. but I will have so much of the sheet left over as I only need about a third of the m2 that one of these sheets covers. I suspect I may end up having small tiles instead. I thought one of the southern country member might have some lying around in your sheds. Cheers. Ray
Post by shesgotthelook on Apr 15, 2019 21:43:28 GMT 10
Post by Franklin1 on Apr 15, 2019 23:27:41 GMT 10
G'day Ray,
Have a look at the tile featured in this link . Notice the tile is a standard 300 x 300mm but could be cut in half to give you your 150mm height requirement.
Also notice down the bottom of the description: "Our recommended pressed metal installer: Andrew Gay - Mob: 0418501111 Email: pressedmetal@outlook.com". Andrew might be just the guy to make contact with to discuss your situation and give you some hints on what options you have, etc.
Post by Roehm3108 on Apr 20, 2019 8:45:09 GMT 10
G'day Al
Thanks for the info. With a depth of up to 1cm, it would be difficult to waterproof those tiles. I think I might take the coward's way out and use the KISS method of simply tiling.
