Post by nugget on Jul 8, 2010 20:16:02 GMT 10
Post by cobber on Jul 9, 2010 9:53:38 GMT 10
G'day Nugget, WHAT'S SPECIAL ABOUT YOUR COUPLING  …....... mate, it's the first example we have seen of that flat mounting type of coupling adapted to fit the round shaft of an over-ride brake....THAT'S SPECIAL  Don't let 'em talk you out of keeping it on the 'van when you take it to get registered. Turning your springs upside down could be a first too  They probably were talking about putting the springs on top of the axle instead of under it.... might have to turn the axle upside down depending on the set up you have. Cobber
Post by cobber on Aug 10, 2010 7:31:06 GMT 10
This here is the tow coupling on Reddo's latest acquisition.  Don't know if it has a brand name on it or how the hand brake locks 'on'...... Reddo might fill us in there  Cobber.
Post by Franklin1 on Aug 31, 2010 17:55:42 GMT 10
This coupling is currently listed on ebay. No information about what it's from or why it's being listed on its own...
Post by cobber on Aug 31, 2010 19:23:10 GMT 10
G'day Al, That coupling appears to be in good nick for what it is. It's the same coupling that earlee had that started this whole tow coupling thread back in 2005. I also had it on "Free to a good home Mk 1". back in 2004. Be interesting to see what it fetches on ebay  Cobber.
Post by Franklin1 on Aug 31, 2010 21:44:17 GMT 10
cobber, for some reason the ebay auction "ended" without any bids. By coincidence, another little van has been listed that appears to have the same coupling...  The seller says the van has something to do with being the first aluminium van built in Shepparton, Vic. in 1954, although the stable door points my attention towards Qld. Al.
Jikah
Post by Jikah on Sept 1, 2010 0:05:56 GMT 10
Hi Al,
That tow coupling looks like a "Henderson" brand made by Henderson Springs, which was around Newtown or Alexandria, in Sydney, from memory. They supplied springs, axles, brakes, couplings and other bits and pieces for caravan builders. Don't know if they still exist. I accompanied my Dad to Hendersons where he purchased this coupling for the caravan he was building, when I was about 9 or 10 old, in the early fifties. Had great times in that caravan.
Cheers, Ian.
Post by cobber on Sept 1, 2010 8:55:28 GMT 10
G'day Ian, Thanks for that information..... now that you point it out if we look at the Henderson thread in DHL we can see the coupling in photos there. Apparently in those days there was no requirement for manufacturers to brand their couplings, which can cause restorers problems with the "Blue slip" inspectors if we want to retain these old couplings and they don't know the relevant rules. Cobber.
Post by cobber on Sept 3, 2010 10:34:23 GMT 10
This coupling is fitted to Sportsman 1's Clipper.  The original one looked more like this.... home made I suspect   Cobber.
Post by sportsman 1 on Sept 3, 2010 13:28:41 GMT 10
if you have a look at the pics of the original Treg type coupling it showed the tube part welded to the drawbar and the coupling through it.
I have several possible tow cars and the thought of having to put on and take off the other part of the Treg to each car every time I wanted to go somewhere seemed a lot of trouble as well as the fact they are notoriously hard to put the two halves together.
Some time ago I advertised for a 50mm override coupling to do a conversion. Seeing as the override coupling has the same diameter shaft as the Treg I figured if I take the ball coupling off the override and shorten it to suit I could fit it into the original tube. This gives me a ball coupling for multi use without destroying any of the original bits. If I want to I can just take the nut off the end of the ball coupling, remove it and replace the original.
I did cut the handbrake bits off the ball mount as they were not required. I know it is not original but hey, it works for me!
Cheers, Leigh.
Post by cobber on Sept 12, 2010 19:07:55 GMT 10
This coupling is fitted to kazandadams Quest caravan. We need to know what the vertical bit does..... it slides independently of the override brake shaft See how the hand brake ratchet appears to have been broken and originally may have flipped over to engage the vertical bit in question   Made by "Western"...... maybe Tucky or Cus or the "Sunliner" boys have seen this coupling before ?  Cobber.
minor man
life is to short
Post by minor man on Sept 17, 2010 22:22:48 GMT 10
Post by cobber on Oct 9, 2010 16:02:16 GMT 10
Photo off an un-named 'van on e-bay. A variation of a coupling we have seen before  Cobber.
Post by cobber on Nov 15, 2010 7:42:35 GMT 10
Post by cruisindoug on Nov 15, 2010 10:23:57 GMT 10
The coupling that was on our Skyline:  Won't be using it (it isn't in great condition underneath) but will be keeping it - any takers as to date and / or if its the original? Cheers Doug & Tracy.
Post by cobber on Nov 15, 2010 10:56:26 GMT 10
G'day Doug 'n Tracy, This coupling appears to be a 2 ¼ '' coupling... which is very interesting. This add from 1959 gives a bit of a clue as to its approximate age ....... all we have to do now is find out when it first appeared, and when it was replaced by the 2 '' ball. Stay tuned.   Cobber
Post by cruisindoug on Nov 15, 2010 13:42:40 GMT 10
Thanks Cobber, it seems to fit in as being as an original coupling for the van, amazing its still there. Cheers Doug & Tracy.
Post by cobber on Jan 9, 2011 9:12:31 GMT 10
An ingenious English tow coupling from 1937 that I haven't seen in Australia..... if you have, show us a photo of it   Cobber.
Post by firefighter on Jan 27, 2011 14:23:26 GMT 10
 ::)G 'Day olfart Dave that handle and threaded spindle in photo 2&3 is from a fire sprinkler installation in factorys/shops/office blocks etc that turns the water off & on f/f ;D ;D ;D ;D ;D ;D
Post by JBJ on Jan 27, 2011 17:31:57 GMT 10
Hi Dave,
They would be the prototype experimental aluminium windows in 1952. Like the 52 sunliner on ebay at present ( really more a 62)
Cant make people accept reality if they aren't interested.
Nice van still.
Post by cobber on Jan 28, 2011 10:50:23 GMT 10
Thanks for those photos Dave and thanks to F/F for the information about the Jockey wheel on the Bethanga van.... you didn't notice what brand name was on that one did you Dave ? The other one on the home made job we have seen similar before I think but we didn't know it was a "Dymwood"........ or did we  Cobber. Yes..... back on page 3 reply # 43 we got the clue it was a "Dymwood"
Post by cobber on Jan 28, 2011 10:52:31 GMT 10
This I was told is a “Show Van Coupling”. The screw on lid pictured is used when the coupling is not in use but....... the ball passed through a similar lid that also screwed on and held the ball in contact with the socket.... plus the weight of the van would have kept it in contact.  I am assuming this part attached to the tow vehicle.....I am also assuming we are talking about Showmans 'vans or “living vans” as the Poms call them.
RS 1990
I've finally managed to return after almost 10 Years!
Post by RS 1990 on Feb 10, 2011 19:14:52 GMT 10
An ingenious English tow coupling from 1937 that I haven't seen in Australia..... if you have, show us a photo of it   Cobber. That looks similar to Lego pieces!
Post by Jennison on Feb 27, 2011 18:40:50 GMT 10
Enquiries from another member of the forum have prompted me to go get some more comprehensive photos for this towball connection thread of a complete jones dolly wheel setup. It's on a VV that I have had in my wish list book for a while now. The owner wishes to REMAIN anon  I will send the photos to Cobber to add when and where he thinks fit Enjoy ;D jennison ;D
Post by cobber on Mar 1, 2011 7:32:54 GMT 10
G'day Jennison  I have put these photos over on the thread devoted to "Dolly wheels". Thanks for sending them to me, the Dolly Wheel thread is HERE.Cobber.
