Post by shesgotthelook on Jan 11, 2014 9:21:50 GMT 10
Post by shesgotthelook on Jan 11, 2014 9:29:18 GMT 10
Post by shesgotthelook on Jan 11, 2014 9:33:15 GMT 10
  Thus far; one side cut out & replaced, door has new ply & back window which had been sealed up with chipboard is now cut out ready for new one.
Post by akeepsake on Jan 11, 2014 9:58:45 GMT 10
Nice little van what's the inside like? Looks like your having a crack! Will watch progress with interest
Post by Deleted on Jan 12, 2014 9:11:55 GMT 10
Hi sgtl, good looking little van, looking forward to see more pics of her restoration. Cheers hughdeani
Post by shesgotthelook on Jan 27, 2014 14:47:36 GMT 10
Post by hilldweller on Jan 27, 2014 18:20:18 GMT 10
Lovely pattern though, on the floor. Hope you manage to salvage it. The new cladding looks great and I love the fridge
Post by shesgotthelook on Jan 31, 2014 13:30:52 GMT 10
New tail with 'stucco aluminium'
Post by shesgotthelook on Jan 31, 2014 13:34:04 GMT 10
Have encountered a window crisis today. You can see the original rear window is long gone & had been filled in with a piece of chipboard. The glass people in Echuca say they can't make a curved edge frame, only square?   Where do I go? It is a fixed window.
Post by kaybee on Jan 31, 2014 15:03:26 GMT 10
Hiya,do you mean the corners of the sheet need to be cut rounded to match the opening , or is the glass surface curved?...'coz the opening looks flat in the pics......
Post by shesgotthelook on Jan 31, 2014 16:13:52 GMT 10
I think they mean the frame to sit it in? The opening is flat. Surely they cut curved corners on glass to replace the broken ones for the frames on opening windows I took up? I don't really understand why they couldn't do it.
Post by kaybee on Jan 31, 2014 16:53:27 GMT 10
G'day again , did you mean you wanted an aluminium frame for the glass to sit in,and that's what they can't do?....if the window is a fixed unit, why not sit it in a rubber seal like most of that era's van's had....and leave the alloy frame out of the equation. The rubber seal thing is simple enough to do , a visit to Clark Rubber will get you the proper rubber extrusion section,then all you have to do is make a plywood pattern of the actual opening ,then trim off the thickness of the inner rubber core where the glass sits. That gives you the glass size , and then you get the glass guys to make the glass from the pattern.
Post by Geoff & Jude on Jan 31, 2014 16:53:51 GMT 10
if it's the glass you're talking about, i'd suggest you go to a different glazier.
it's not unusual to have rounded corners cut, i can't imagine why they couldn't do it.
if it's a fixed window frame, i reckon there wasn't a visible external frame there in the first place and the glass was set from inside the van. there was/is probably a square cornered frame inside the van that is slightly (maybe an inch or so) larger than the window opening.
inside the van, the "overlap" is prepared with putty and the glass is positioned/pressed (from the inside) against the rear panel (within the frame) and the metal cleats hammered in to retain the glass.
the inside is then re-puttied to dress the finish and the outside is also puttied and dressed to seal the outside joint.
if this method is used, there's no need to have round corners on the glass, the rounded corner shape is created by the shape cut into the body.
either that or what kaybee said.
Post by hilldweller on Jan 31, 2014 18:41:46 GMT 10
Or if neither of the above works buy a second hand curved corner window - with or without glass - from a 'donor' van.
Post by Deleted on Jan 31, 2014 19:09:10 GMT 10
The glass people in Echuca say they can't make a curved edge frame, only square?   What type of glass are they quoting on? Automotive? Toughened? Laminated? Great job btw!
Post by shesgotthelook on Jan 31, 2014 19:50:18 GMT 10
Thanks so much everybody, all makes sense now. Geoff n Jude, I think you are on the money. It does have the square wooden frame inside the van but Kaybee, what you suggest is what I was trying to explain to my builder man. I think I will print all this out, along with pictures & go to the various industries myself, including the caravan shop. I do think the glass folk were thinking it needed an aluminium frame like the opening windows. Hilldweller, if only I could find a cheap donor van! Should never have sold my $2 caravan  Another query, would painting the very rubbed, stained & discoloured roof & tatty looking J mould with zincalume or similar be a big no no?
Post by kaybee on Jan 31, 2014 21:36:39 GMT 10
....it might look a bit crap ,just my opinion of silver paint, it always reminds me of Kromebright spray paint. Best result would be to rub it all back as smooth as you can get the surfaces and use something like a medium gray acrylic ,put on with a short nap roller so it doesn't get too "lumpy".....and if you're doing it in warm weather you need to add some retarder like "Flowtrol" to allow you some time to roll it on before it starts to dry out. The J mould will look a bit daggy if you paint it ,but a lot depends on your expectations and satisfaction level. I get a bit stuck on detail and definition ,but other folks don't and seem quite happy with that ,so I guess it all comes down to what you'll be happy with. You can always mask off the J mould and paint strip it back to bare,then give it a light rub with steel wool and clear coat it.....or put new stuff on if you're not happy with the look.....cheers.
Post by shesgotthelook on Feb 11, 2014 8:34:35 GMT 10
Post by shesgotthelook on Feb 11, 2014 8:40:08 GMT 10
New front spats (Ugly phillips head thingys will be replaced)  New old tap replaces newer old 80's? tap. Water tank appears ok. I thought the outlet had been sealed up but upon poking with something pointy, the water I had put in it poured out
Post by shesgotthelook on Feb 11, 2014 16:33:21 GMT 10
Post by shesgotthelook on Feb 15, 2014 15:16:18 GMT 10
Post by shesgotthelook on Feb 25, 2014 14:27:52 GMT 10
More serious sanding. I was reluctant to lose the original flash but it would have come through the new paint.
Post by shesgotthelook on Feb 25, 2014 14:30:58 GMT 10
Post by Franklin1 on Feb 25, 2014 19:59:21 GMT 10
The van is coming along quite nicely, sgtl. It's certainly looking heaps better with all your hard yakka.  I was wondering how you fixed the framework that was rotten in the back bottom corners? You posted the 'before' photos, and then skipped straight to the finished cladding photo. I'm curious to know how you got it sorted. The other question I have is about the rubber moulding for the back window. I also have to go through this process in the future, so do you know what the radius of the old window corners were, where the rubber wouldn't bend around the curve? Looking at your photos, I think the glass in my van has curved corners that are fairly close to your old glass, and I'm wondering if I'll strike the same issue that you've discovered. Is that the Clark Rubber stuff you're using? ps. I hope hubby is busy polishing the Phoenix badge, now that he's mastered the art of polishing porthole windows.  cheers, Al.
Post by shesgotthelook on Feb 26, 2014 10:01:44 GMT 10
Window problems- I am assuming the rubber from the original rear window on your van is not in great shape & not re-useable? The ClarkRubber profile we are using is too tight in the original corners to allow the glass to be placed in it. The radius of the original is 9.5cm. If I had a completely aluminium back end, would not have had all these problems, or so I'm told but I've dug my heels in & retained the wood  I'm a firm believer in 'if something doesn't work, try a different approach'. Re the rotten corners, well I have to admit, I threw money at a retired builder for all the tricky bits & he had it done & the sides on before I got a pic. But I do know he cut the shape out of pine? using the original as a template. They were quite wide pieces, not like steam bent or ply layered corners.
