Post by Franklin1 on Mar 18, 2012 11:33:27 GMT 10
Post by seeshell on Mar 18, 2012 11:41:28 GMT 10
Hi Al
Very sad - and it certainly makes a case for not having any gas inside the van doesn't it?
Just so risky.
Seeshell
Post by shesgotthelook on Mar 18, 2012 14:33:15 GMT 10
Post by overlanda on Mar 18, 2012 16:00:16 GMT 10
Gas appliances are safe to use in caravans providing they are designed for that use, and fitted in as they are designed to and with the right flue and or ventilation not blocked off, because it creates a draft or some other poor excuse . Then blame the appliance for causing a problem when some one stuffs up for example using the oven for a heater by leaving it on high with the door open on the oven . There are plenty of other cases were similar things have happend,and i have seen plenty of them personaly in my 38 years in the caravan trade and it is realy annoying to see people and hear people blame something that is caused by stupidity.
Post by Roehm3108 on Mar 18, 2012 16:06:08 GMT 10
What a sad event this was, and even sadder that it happens all too frequently. Gas appliances need to be treated with respect and care. The internet is full of safety hints on using gas in caravans. Here is just one of them whatspot.com.au/tips-and-guides/caravan-safety/Of course, you can also now get gas detectors as an added precaution. Ray
