Post by bobandjacqui on Feb 25, 2011 17:18:38 GMT 10
Here's a project van for someone with a few skills. Olympic Riviera chassis number 1350 which makes it a 1967 model. The good bits are that the chassis is OK just the usual surface rust. The hard to get bits ie the door/hinges/hatch are intact. The bad bits are the cab needs to be lifted off the chassis as the floor needs replacing. It would need new bearers and floor fibreglassed back into it. Two windows are missing and one needs the glass replaced. All other window glass is intact.
I will post some photos shortly. If there is any interest please send me a PM. The van is located at South Maclean SE QLD.
Cheers Bob
Post by bobandjacqui on Feb 26, 2011 5:48:27 GMT 10
As promised a few photos of "Orphan Annie" This van is sadly neglected as seen in the photos There is no furniture left inside only the top moulded cupboards. Cheers Bob and Jacqui
Post by JBJ on Feb 26, 2011 7:48:29 GMT 10
Hi All,
Just to let everyone know, we need a window assembly like the middle one on the right side, 900 overall length & 400 deep, to put into Deejay. That will restore the original style to its side window that has been added sometime in the past. Happy to pay a reasonable price, but want it complete with all bits. Broken glass is acceptable, same as damaged screens.But I dont want to be chasing hinge & catch bits. May as well buy a new one as look for bits.
Let me know if you have one
Post by banno on Feb 26, 2011 8:11:37 GMT 10
Gidday Bob, looks like a little bit of work there. The orphan should still come up a treat though. The best thing with this project is that someone could make the interior however they wanted to.
Banno
Post by boblor on Feb 26, 2011 21:21:14 GMT 10
Hi Bob and Jacqui A nice save there, surely someone will see this as a good project. The cabs were built with more glass in them in '67-8, so this one should clean up well, first thing is to waterproof it to stop any further damage. So from that point of view, the sooner someone puts their hand up the better. Another one for the register. Cheers boblor
bradh
Post by bradh on Mar 2, 2011 15:03:42 GMT 10
Hi just wondering how much you are asking for it and is it towable?
case
Post by case on Mar 3, 2011 18:47:26 GMT 10
Hi bobandjaqui, How are you both, a quick question on the Riviera Shell for sale, why would you need to take the cab of the chassis to repair the floor, as the floor and joists are above the fibreglass bottom.? Hope to see you at the Nationals.
Post by bobandjacqui on Mar 4, 2011 5:51:32 GMT 10
G'day Case, Your right, the floor could be repaired just by jacking up the cab to get it back in shape and putting in the new one. The shell was used for storage and the weight of the stuff stored put pressure on the internal walls. Also all the cupboards etc have been removed which normally give the cab internal strength In my original description I didn't want to give the impression that this project is an easy fix. This Van is well worth saving. It will be good to catch up you both at the Nationals Cheers Bob and Jacqui
Post by seeshell on Mar 4, 2011 8:12:39 GMT 10
Hi there Bobandjacqui
Only because I'm not that far away from undertaking the process of fixing the floor - could you tell me exactly where and how you would jack the body up? What points specifically? How would you recommend supporting the shell? (I'll have a chat to Boblor too...)
It might be an option before we go the whole body off route if the chassis isn't that bad. I'm going to see if I can't get a look at the chassis underneath to determine if the rust we can see needs a more serious treatment or if we can do what we have heard others have done - which is jack up the front, deal with the chassis with POR15 and paint, let her down and repeat on the other end. I was making an assumption that when this had been done in the past the shell was empty - but was it?
Any advice greatly appreciated. Seeshell
Post by Franklin1 on Mar 4, 2011 9:46:55 GMT 10
G'day seeshell, There's some interesting reading in tonyh's thread about his Olympic restoration: Our Olympicatog's Olympic was another major restoration, although he put a much more detailed story on the Classic forum, at this link: Atog's 68 OlympicAdd those threads to all the good info you'll get from Olympic owners, and your restoration is as good as DONE!! ;D ;D cheers, Al.
Post by seeshell on Mar 4, 2011 11:04:52 GMT 10
Hi Franklin1 I had poured over Atog's site, and read Tonyh's before, but you're right - you do pick up much more on the third and fourth reading. Much appreciated. Some very good work done by both gents - I get inspired and terrified each time I look at their posts. It appears people have been VERY reluctant to separate the chassis and body. Case mentioned, when he was around the other day, that Boblor had done the bum-up, bum-down, front-up, front-down chassis cleanup so I'll pick his brain. Poor Bob, he's not going to have much left the way we're forever taking bits of it! Thanks all Seeshell
Post by bobandjacqui on Mar 4, 2011 11:53:55 GMT 10
G'day Seeshell, I have never had to lift a cab off but those links Franklin1 put up show how it's done. Good luck with your resto. ;D ;D ;D Cheers Bob and Jacqui
Post by bobandjacqui on Mar 6, 2011 17:00:16 GMT 10
This van is SOLD and is going to a new home on the Gold Coast. That's another Vintage caravan saved from the tip ;D ;D ;D ;D Have to be happy with that Cheers Bob and Jacqui
Post by banno on Mar 6, 2011 17:33:46 GMT 10
Gidday Bob, that is good news. So this means that now the Olympics have a new Steve.
Banno
Post by boblor on Mar 9, 2011 14:31:11 GMT 10
Hi to another Steve Welcome to the Olympic family, another great save, only too pleased to offer advice as and when required to get this unit on the road and at our rallies. Cheers boblor
