Post by greedy53 on Nov 3, 2010 6:42:25 GMT 10
I am looking for advice on the dest way to paint my tear drop I am looking for a vintage look as I have tryed to follow the building of a old one on a wed site.you can see my little bugger on the members photo album section,under home built tear drop Any advice would be great,
Post by JBJ on Nov 3, 2010 7:10:51 GMT 10
Hi,
I believe the best way is to paint by brush, using enamel full gloss paint. Thats what would have been used in the past.
Look at Reddos teardrop thread, & the one on "Lucille" I did a while back. Theres heaps of info & comments about painting on the Forum, just a matter of finding where its stashed.
Post by Deleted on Nov 3, 2010 13:16:17 GMT 10
Hi Greedy A lot of paint suppliers are recommending using acrylic nowadays. I have seen some good finishes off a spray gun with both enamel and acrylic..... But .. after painting at least 4 vans i will stick to my guns and recommend that if you want an original look and a good gloss finish go with oil based enamel. I used a short napped roller on the large flat areas and cut in around the windows / doors etc with a 1"brush. Give it at least 2 good coats . with a light sand between each one after it has dried. Then put a top coat on "laying off "with the brush as you go . Laying off simply means applying the top coat ( use a 4"brush for the top coat if you have the patience) with no weight on the brush . and long straight strokes. Only other advice i can hand ya is to make sure the surface is well dusted off between coats and sanding. get the timber as warm as you can on a sunny day and sit the paint tin in a warm saucepan of water. The warmer the water the better the paint will flow and level off without brush marks.. Go for it mate Reddo
Post by cobber on Nov 3, 2010 15:36:21 GMT 10
G'day Greedy, Your question has been asked maybe a dozen times on the forum over the years if you click here you will be able to read one of the most comprehensive discussions on the subject. Cobber.
Post by greedy53 on Nov 3, 2010 17:42:53 GMT 10
thanks all i knew i would find hope here
