Trish_M
1950's Home Made Bondwood "Bettie Moonya"
Post by Trish_M on Aug 4, 2008 20:53:36 GMT 10
Hi there, my old Fairholme arrived today and I am just wanting to know about the gas lights which are "Calor" gas lights made by "Veritas". Is Calor gas the same as LPG? Also I am looking for a glass shade for 1 light and am not sure what type of mantles that they take? Here is a pic of the lights: Thanks, Trish.
Post by Franklin1 on Aug 4, 2008 22:01:09 GMT 10
Hi Trish, there will be people much more knowledgeable about this gas than me (...cobber, uk brian, etc), so I'll just post this link for you to have a read of the "frequently asked questions" about calor gas... www.calor.co.uk/faq/which-gas.htmNote the information about the two different gases involved, and the need for different regulators depending on the type of gas used. cheers, Al.
Trish_M
Post by Trish_M on Aug 4, 2008 22:26:04 GMT 10
Thanks Al!
Post by minicamper on Aug 5, 2008 14:07:44 GMT 10
Trish, when i migrated here, we bought all our British camping stuff with us. From memory, at the time the Brits used Butane not Propane (LPG) and mostly camping GAZ which is available here, but only in disposable packs from what i saw. We couldn't use our stove as it was a 2 burner that mounted on a 4kg Gaz bottle and couldn't be filled, so Mum and Dad gave up and went LPG.
You should be fine using the commonly available Gasmate mantles as these can be used in most fuel lamps (gas, kero, petrol etc)
As far as gas source and leaks, speak to a local plumber just to be safe. I can't rcall whether LPG and Butane have the same jet sizes and that would be the main concern.
Trish_M
Post by Trish_M on Aug 5, 2008 14:29:56 GMT 10
Thanks Chris Much appreciated! Trish.
Post by trodler on Aug 6, 2008 17:05:52 GMT 10
Hi Trish. Just about the gas lights. I have one in my yellow van and ( it may be different in Vic ) but the gas light wont pass when you get a LPG certificate for the van. It is all to do with the on and off valve connected permanently to the line, they were OK back in the 50s but they are a bit dodgey now. I still have mine in the van but it is disconnected and there for show only. (dont tell any one.)
Cheers. Trodler
Post by humpty2 on Aug 6, 2008 19:38:47 GMT 10
That's handy info regarding the gas lights.....I didn't really want to hook them back up again in the Carlight. Only decoration. ;D
