Post by Deleted on Aug 9, 2007 8:55:03 GMT 10
Post by Franklin1 on Aug 9, 2007 10:14:55 GMT 10
By gee, reddo, poor old KB2 (Admin) must age a bit each time she sees one of your posts. Finger hovering over the "delete" button...groaning...trying to decide how much she'll let you get away with... But very good info in your link. And adding to your theme, there's an interesting towing hitch on ebay at the moment...item # 180146698843... Where do these originate from? Al.
Post by Deleted on Aug 9, 2007 10:29:11 GMT 10
Yo Havent read the ebay description of this thing . but by the look of the square section it is/was probably marketted by hayman reese. Looks like it would have good shock absorbing qualitys with that big springy thingy in there.
Might take a bit of the jarring effect away from the tow hitch anchor points on the car. Reddo
lazza
Post by lazza on Aug 9, 2007 20:29:53 GMT 10
Howdy, the tow head with the springy thingy was designed and marketed by Eric Hayman of Hayman Reese fame. It was his retirement project meant to be used behind any truck/4 wheel drive etc that had a very stiff and unforgivivg rear suspension Regards Larry W
Post by trodler on Aug 9, 2007 20:53:58 GMT 10
Hi V V ers. Lazza is correct.These tow hitches were designed to be used on the back of a four wheel drive, probably around the mid 80s. Back then caravan manufactures wouldnt garantee there vans if they were towed by a 4 wheel drive with out one of these or a tow bar with the tongue on a rubber torsion arm.
Cheers. Trodler.
