Post by brenten on Dec 25, 2015 17:13:15 GMT 10
hi guys i hope you all had a great xmas day.. the furness van we are doing is missing the latch to hold the roof hatch closed ..i dont know what the original one looks like so im not worried if its not correct .anybody have a old latch for sale please ...robyn and brenten 0408346524
Post by JBJ on Dec 25, 2015 19:19:52 GMT 10
Hi Brenten
I had a lot of problems keeping the hatch on my Olympic down. I eventually used the rubber catches used on bonnets & industrial doors
They are easy to operate, & have solved the problem I had.
As regards period correctness, I remember them from the 50's, in various applications
They are available in different lengths I believe.
If you need photos, I can take some tomorrow & post here for you of my installation.
Post by cobber on Dec 25, 2015 19:56:44 GMT 10
G'day Brenten, Does your hatch also need a 'holder upper' as well as a ' holder downer' There was discussion about them on this thread HERE Cobber.
Post by brenten on Dec 25, 2015 22:37:13 GMT 10
thanks jbj i dont have very much height in the vent box in the roof so im not sure your idea will work...brenten
Post by brenten on Dec 25, 2015 22:39:53 GMT 10
thanks cobber i have the holder upper .brenten
Post by Rattles on Dec 26, 2015 7:24:59 GMT 10
Post by brenten on Dec 26, 2015 7:28:31 GMT 10
thanks rattles i have space for this type of fastener ..brenten
Post by JBJ on Dec 27, 2015 16:41:18 GMT 10
Hi Brenten The catches I used aren't much bigger than those wind down ones, & don't come loose like the metal ones do. They were found on Ebay, & are about 50 mm long in the rubber body. I have tried the metal hold downs, & they kept coming undone while travelling. I find the rubber doesn't come undone if you install it in tension JBJ
Post by brenten on Dec 27, 2015 17:21:30 GMT 10
i didnt know they made them that short ....they would work..brenten
Post by moparman on Dec 27, 2015 22:16:13 GMT 10
Post by brenten on Dec 28, 2015 0:08:09 GMT 10
thanks moparman i like the first one being spring loaded it means every time i close the hatch it self locks that would be great i will go and look at one......brenten
amy
Post by amy on Dec 28, 2015 10:05:25 GMT 10
This is the type of latch that I have in my Furness caravan And it just slides into a hole in a bit of wood
Post by brenten on Dec 28, 2015 10:14:40 GMT 10
Thanks amy thats different it looks like it was made by furness caravans i reckon I can make of those i have the screw holes to work out the size thanks again. ...brenten
Post by cobber on Dec 29, 2015 13:07:17 GMT 10
G'day Brenten, If you're heading down that path maybe the cupboard / wardrobe bolt shown near the top of THIS PAGE might do the trick Cobber.
Post by brenten on Dec 29, 2015 13:22:09 GMT 10
thanks cobber code..c 166..100fb looks the closest......but im good with cutting, folding, drilling, welding metal im sure i can copy amy,s photo and make a pretty close copy of the furness latch if not i will buy the 100fb.....brenten
