Post by robbo3 on Jan 13, 2014 17:49:46 GMT 10
I was wondering what tyre pressures the people using 13 in holden wheels were using?
Post by Franklin1 on Jan 13, 2014 18:08:25 GMT 10
G'day robbo3,
I can only tell you what works for me, not what theory says I should be doing...
The following is from the NRMA caravan info site:
"4 psi rule":
"Tyre pressures - do-it-yourself check
It is impossible to list the correct pressures for every caravan, due to variation in size, load, etc. This easy check will help you find the best pressure for your caravan tyres.
1: First inflate the tyres to the pressure recommended by the manufacturer of the trailer or the tyre you are using. Secondly, tow your trailer for a distance of 100 km, preferably on a highway.
2: Recheck the tyre pressures immediately after pulling over and compare them with the pressures you had at the start of your run. If the pressures are right, the hot readings should be 4 psi (28 kPa) higher than the cold readings.
3: If there is a greater than 4psi (28 kPa) difference between these pressures, the tyre temperature is too high and the pressure needs to be increased. If there is less than 4 psi (28 kPa) difference, the pressure needs to be lowered.
4: Large 4WD tyres will have a differential of 6 psi (42 kPa).
5: Be sure to use the same accurate gauge for both readings."
And this one from another forum...
"Another way to find out approximately what pressure you should run is from a very simple formula derived from the tyre specifications:
max tyre pressure and max load rating are shown on the side wall of the tyre. Plus you need to know the weight of the van you'll be towing...
max tyre pressure divided by max load rating times actual load per tyre
for example: 450Kpa / 950kg x 450kg = 213kpa (30psi)"
I have successfully used the 4 psi rule for both a van with 13" Holden wheels with L/T tyres, and a van with 14" Holden wheels with L/T tyres. In both cases I've started with cold pressures of 40 psi. I've towed both those vans for a combined distance of nearly 12,000 kms, and haven't had any problems with tyres. I certainly wouldn't preach to you that you should do this or do that with respect to tyre pressures. I can only say what's worked for me.
aquamum
Post by aquamum on Jan 13, 2014 19:37:57 GMT 10
Robbo3
My Holden EJ Ute runs stock size modern radial tyres that have a max pressure of 44 psi
- I run them at about 38 whilst towing my caravan
Have travelled a few thousand kms with no probs so far :-)
Post by Roehm3108 on Jan 14, 2014 7:17:06 GMT 10
robbo, are you talking about tyre pressure of the caravan or towing vehicle??? There seem to be varying responses.
Post by robbo3 on Jan 16, 2014 14:23:26 GMT 10
Caravan,I've settled on 35psi. I'm taking the grandkids away camping leaving Saturday for Wakiti Creek Caravan Park ,near Echuca for a week. Unfortunately we don't own a VV so our Roadstar Little Ripper and an old tent will do the job. This will be the kids first camping experience and it looks like being very hot. One thing you can't choose is the weather, but I'm sure we'll have a great time.
Post by glenora on Sept 19, 2023 10:46:36 GMT 10
Quite interested in this thread also. I have a 1964 Wayfarer Roadliner that weighs in at just under 1,000kg with gas bottle and full watertanks and packed. 100 on the tow ball. I have no idea what the manufacturer GVM for the van is. I currently have 185/R14/LT 102/100s tyres on the van but am having trouble working out the correct pressure with out knowing the GVM or MTPLM of the van. I have been running them at 35psi without problems so far.
Post by Mustang on Sept 21, 2023 17:52:25 GMT 10
I would think 35 is too low, as stated above you need to monitor after the tyres are hot. An increase of 4-6 psi is normal. If there is more then you were under to start, if less you were over.
I run 45psi (cold) in my 14' 6" Walden which is around one tonne with 13"wheels.
We use tyre monitors.
