Post by shesgotthelook on Feb 14, 2013 8:28:11 GMT 10
I am after:
Stove- Falks, Parkinson or similar. 46cm width max
Dinette cushions or materials to match minty? green
Old bar fridge -Know I'm not going to have much luck here! or 2 way white colour as long as 240v works.
Interior light fitting that clips in (get back with pic & measurements)
Old lino
Tail lights- resemble the no. 8. Same as rear of 1962 Viscount.
Happy to pay post on smaller items. Am going to Bendigo with Mexican tour & can travel small distances from Northern Vic!
Post by seeshell on Feb 14, 2013 8:44:01 GMT 10
Hi SGTL
I have an old Parkinson Stove in excellent condition - cream and black enamel, as well as a Falks white and brown. And others...god, packratting.
I have dinette cusions 1200 long in maroon (new foam and covers never used) which go lovely with green (green and red was our planned colour scheme for the Olympic).
I also have some old style lino squares (3mm streaky green) that could work for you.
Plus about a million other bits and pieces.
PM me if you're interested - also going to Bendigo on the Mexican Tour.
Cheers Seeshell
Post by shesgotthelook on Feb 14, 2013 19:30:58 GMT 10
Thanks SS, have PM'd you.
Cannot post photos of light till Telstra give me back my phone no which some smart technician swapped with the people across the road.!
Post by circuscaravan on Feb 17, 2013 12:49:59 GMT 10
What's the Bendigo Mexican tour? Thanks
Post by shesgotthelook on Feb 17, 2013 20:30:29 GMT 10
Mexican tour (south of the border!) Central Goldfields Vic in`April.
Post by Don Ricardo on Feb 17, 2013 21:52:46 GMT 10
Hi Circuscaravan, The Mexican Tour is referring to a vintage caravan run being held in Victoria at the end of April. If you would like more information click here. It's open to all forum members or other folks with a vintage caravans. People who want to just drop in to say hi at one of the stops, or to check out the vans, are also welcome to do so. Don Ricardo
Post by firefighter on Feb 18, 2013 9:36:12 GMT 10
What's the Bendigo Mexican tour? Thanks G'day circuscaravan Looks like the word Mexican has you stumped ;D ;D ;D ;D Good old aussie slang......thats what i was using when I used Mexican in the write up for the tour People in Australian states are known as Western Australian - Sandgropers Queenslander - Banana Benders or Toadstools Victorian - Mexicans South Australian - Crow Eaters Tasmanian - Taswegians NT/ACT - Territorians New South Wales-New South Welshman or Cockroachers Hope this posting helps you trying to work out.........What the Bendigo Mexican tour is all about Circuscaravan are you coming on this tour ? ? ? ? ? ? cheers f/f ;D ;D ;D ;D ;D
Post by shesgotthelook on Feb 19, 2013 13:29:40 GMT 10
Finally got my inet fixed so here goes ;D Light fitting is 20cm across.
Post by shesgotthelook on Feb 19, 2013 13:31:28 GMT 10
What original lino was
Post by seeshell on Feb 19, 2013 16:26:44 GMT 10
Hi SGTL
I have two matching with chrome bases and glass lights that are 170mm across and have the three grub screws for holding the glass in. Probably early 60s.
Let me know.
Cheers Seeshell
Post by shesgotthelook on Feb 19, 2013 21:36:41 GMT 10
Any chance of a pic SS? I just don't want to have to re-wire anything if I can avoid it. You have been amazing with your help, thankyou.
Post by seeshell on Feb 20, 2013 4:04:21 GMT 10
Hi SGTL These are from a vintage bathroom. I don't think you'd need to move your wiring at all; it would require you to reroute your existing wiring through the fitting, but since there is clearance behind for wiring it's not really an issue. The shades fix with screws and slots (small turn and tighten in the screws). As you can see the shades hold on with three screws. Cheers Seeshell
Post by Franklin1 on Feb 20, 2013 9:03:45 GMT 10
G'day sgtl,
There's something about that 12v globe base in your light fitting that makes me think it's been added to the original light fitting. It's the sort of thing I would do if I wanted to convert a 240v light to make it 12v/240v.
I remember fitting these styles of oyster light fittings to a house extension I did in the mid-1980s, so I wonder whether yours are really vintage or not.
If Seeshell's lights aren't what you're looking for, do a Google search for oyster light images or clipper light images, and you'll see similar light styles to what you've got.
I pick up old versions of these lights on occasions in the Op Shops, but trying to pick up a pair of them would be a challenge. Nobody seems to like them in houses anymore, so you can sometimes see them listed on ebay if somebody's doing a house makeover.
Post by seeshell on Feb 20, 2013 9:20:27 GMT 10
Hi Al and STGL
I had planned to change the fitting inside the lamp. Having looked again at your pictures - it appears the light is side mounted? These are really better as ceiling lights.
Al's right that the oyster lights are readily available - I was in Master's (the Big Blue Shed) the other day and there are heaps of options. Perhaps you could use the 12V fitting and transplant it into a new light?
Cheers Seeshell
Post by shesgotthelook on Feb 20, 2013 10:31:10 GMT 10
Thanks all. There are 3 of them, 2 roof mounted & 1 side wall. I don't actually like them all that much! It's just that I'm scared of having to rewire & not sure if I could find something I like that will fit over lge globe & 12v globe. Will do a bit more research.
Post by shesgotthelook on Feb 26, 2013 10:46:42 GMT 10
I know this isn't caravan related but am hoping one of you hoarders of' all things that might come in handy one day' can help me out. The rubber wheels on this pram have perished badly & I'm not sure how to replace them. I have searched pram & tricycle wheels to no avail. Diameter of wheel is 6" (15cm) & dia of outside rubber is 7.5" (19cm)
Post by humpyboy on Feb 26, 2013 11:12:20 GMT 10
Have you thought of checking out Wheel/Castor suppliers, they may have something complete you maybe able to replace with or you could look at removing the rubber tyre off a new wheel and refitting to yours.
Post by kaybee on Feb 26, 2013 11:28:52 GMT 10
Hiya Carley ,if you don't mind having black "tyres".....you can use big "O" rings....try the Bearing supply in Barry St. Bayswater , or check out plumbing suppliers for big O rings like used in Sewer connections,etc.....or as a last resort,there's a guy in Carnegie( Gary Jones) who specializes in restoring old pedal cars....he did some tyres for us on an old 3 wheel bike , he has the profile rubber made and cuts it to length and joins it .....but he's as slow as a wet week so try the others first. If you need the Garys' contact number,we should be able to scare it up for you,cheers.....
Post by Franklin1 on Feb 26, 2013 11:32:11 GMT 10
Post by seeshell on Feb 26, 2013 13:41:53 GMT 10
Hi Col It's Lindsey (SGTL) who is after the tyres - and I'm sure she'll contact you if she's in need. I'm just awaiting my porthole and polished annex wall hangers (Brass) back from Trev the polisher - what a lovely guy. All other van stuff is on hold for a breather. Cheers! Seeshell
Post by kaybee on Feb 26, 2013 14:07:44 GMT 10
Hi Col It's Lindsey (SGTL) who is after the tyres - and I'm sure she'll contact you if she's in need. I'm just awaiting my porthole and polished annex wall hangers (Brass) back from Trev the polisher - what a lovely guy. All other van stuff is on hold for a breather. Cheers! Seeshell ...ah yes....sorry about that to both of you...must be going a bit bonkers...... ;D
Post by Roehm3108 on Feb 26, 2013 14:22:44 GMT 10
KB said "...ah yes....sorry about that to both of you...must be going a bit bonkers"
It's all that talk about prams and things, KB - must've got you worried ;D ;D ;D ;D
Post by lyneth on Feb 26, 2013 17:21:53 GMT 10
Where abouts are you. I have seen a lot of old wheels in a collectors shop in Mildura.
Lyneth
Post by shesgotthelook on Feb 26, 2013 21:04:45 GMT 10
North Central Vic. about 5 hours from Mildura That pedal car site looks good, might send him a msg when get time. Amazing how we change, I was horrified when it was suggested I could use this pram for my babies & now I'm trying to fix it up ;D
enidb
Post by enidb on Feb 26, 2013 22:34:44 GMT 10
www.bellebannevic.com.au/contact-us BelleBanne in Dandenong have vulcanised rubber onto my horse carriage with steel wagon wheels so that the rubber does not come out of the channeling on roads or tramlines. If those pram wheels are steel, then you might choose to give them a call to see if they can put new rubber on those wheels. I went down the path of trying to get the correct rubber profile for my wagon (which they don't make anymore) and costing out a new die but I would have needed to get them to make metres and metres of it in a viable run and it was going to be too expensive. Someone told me about this company that makes rubber conveyor belts and that they do this to alot of horse drawn wagon wheels as long as they are steel. They bake the rubber on somehow. I wonder if they could help you out. Cheers EnidB
