Post by hilldweller on Jan 17, 2013 7:45:37 GMT 10
That's about it really LOL. Just curious as to what people find most useful for caravan work.
Post by humpyboy on Jan 17, 2013 8:04:05 GMT 10
The basics hammer,both claw and brad, saws, panel,tenon and perhaps a coping saw for some fine work, a good set of chisels a drill with a set of bits, can be hand or electric, a good quality hand plane, some screw drivers (flat for slot head screws only, right cobber? ;D ) and you can never have enough "G" clamps of various sizes you will also find a good quality square wont go astray, then you start getting into the more expensive tools if you can afford (warrent) having them, power saw set up in a work bench, router,sanders, drill press, jigsaw ect ect, oh and dont forget "G" clamps, you can never have enough ;D that should get you started.
Post by redmr2red on Jan 17, 2013 8:13:49 GMT 10
Tubes of plasic wood, automotive body filler and no more gaps to correct all the mistakes I make using standard wood working tools.
;D ;D ;D
Post by humpyboy on Jan 17, 2013 8:20:43 GMT 10
Tubes of plasic wood, automotive body filler and no more gaps to correct all the mistakes I make using standard wood working tools. ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D good one.
Post by Miss Molly on Jan 17, 2013 9:17:49 GMT 10
yellow pages....
Post by Franklin1 on Jan 17, 2013 10:31:10 GMT 10
Apart from tools, don't forget to have a vocabulary of really interesting swear words. Many's the time I've called a piece of timber "you miserable piece of sassen-flatzen jibberd" when it didn't do what it was supposed to do. It helps with the "Aah, I feel better now"-part of the process. ;D cheers, Al.
Post by Roehm3108 on Jan 17, 2013 17:48:29 GMT 10
Adding to Humpyboy's list
I use a half sheet sander and a smallish belt sander (Mine's 457mm) a lot. As well, don't forget little things like nail punches. Don't forget things like safety goggles and ear plugs (so you can't hear your own swearing ;D ;D)
Always have plenty of varying grades of sandpaper on hand too - I buy it by the metre or roll. Then of course there are things like wire strippers and crimping tools.
The list goes on ............
Post by Roehm3108 on Jan 17, 2013 17:56:54 GMT 10
2up
Post by 2up on Jan 17, 2013 18:41:24 GMT 10
I found the most useful tool is patience, better slow and steady rather than rough and ready!!!! Oh ,tape measure, measure twice cut once!!!
Post by atouchofglass on Jan 17, 2013 18:54:37 GMT 10
Post by humpyboy on Jan 17, 2013 18:55:06 GMT 10
Another thing I just thought of and best of all it's free, "THINK" if you find yourself at a point not knowing which direction to go in STOP! and think it through and if you still can't come up with the answer then put a post up here on the forum and ask ;D
Post by Roehm3108 on Jan 17, 2013 20:43:28 GMT 10
Gee ATOG, and here I was thinking you were a fobbergrass man through and through. Maybe one day you'll cross over from the FAAARRRRR side and show us how to REALLY restore a timber vintage caravan ;D ;D ;D Ray
Post by atouchofglass on Jan 17, 2013 21:06:52 GMT 10
Timber is to fibreglass, what lipstick is to a pretty woman Too much is tarty... just enough.... well ....va va va voooom!!!!!! ;D ;D ;D ;D
Atog
Post by Roehm3108 on Jan 18, 2013 6:28:31 GMT 10
Yeah ATOG, but underneath that lipstick, she's still plastic ;D ;D ;D
peter
Post by peter on Jan 18, 2013 7:57:30 GMT 10
the most imporant tools to repair old vans are PATIENCE and PERSERVERANCE
Post by atouchofglass on Jan 18, 2013 16:31:00 GMT 10
