Post by Franklin1 on Nov 26, 2012 21:47:29 GMT 10
G'day Rod, It doesn't strike me as being a Franklin at first glance, but anything's possible at this stage. Can you tell me exactly whereabouts on the drawbar you found the number? I only ask because Coronet vans that have appeared on the forum have the number welded on the inside of the drawbar channel arm on the doorside, about where the arm starts to disappear under the front of the van. Coronets had a numerical system (no letters), whereas Franklins maybe had only the one year with numbers only (1960??), and got letters included in '61-'64. Is there any sign of a signature Franklin shelf just above the sink? It'll have a single triangular bracket located under the centre, holding it up. A wittier person than me would say this van's worth working on, even if it does look a bit ragged around the edges. cheers, Al.
Post by cruisindoug on Nov 27, 2012 6:39:44 GMT 10
Hey Rod congrats on another one!
I reckon the front of that looks pretty close to ours ... but the wheel arches not quite Franklin / Skyline that I can see from the pics but not to sure about that.
Is it bondwood sides and aluminium roof?
Cheers
Doug
donald80
warwick q.l.d.
Post by donald80 on Nov 27, 2012 6:57:51 GMT 10
Al i can't work out photo bucket yet so asked rod to post photo's i properly sent them to him in small size and they wouldn't blow up. getting back to the old fan the numbers 286 are on the inside of the A frame under where the curve of the caravan rolles under on the opposite side to the door .it has a window above the sink on shelf but it does have a shelf above the frount windowabout two feet long with triangular brackets on each end on top holdind it up.the wooden screen door in side the main door seems like ones i have seen on old franklin vans the van is not as ragged as the photo,s show .i am getting it weighed this morning and it is 14ft 3ins by 7ft cheers Don
donald80
warwick q.l.d.
Post by donald80 on Nov 27, 2012 7:03:29 GMT 10
yes it has bond wood sides aluminum frount to back keep asking questions i'll try to answer them don
boots
scootin' along the highway of life
Post by boots on Nov 27, 2012 7:28:31 GMT 10
Hey rod strange how these vans follow us home hey Perhaps we need 10days in a week all being daylight, As there is not enough in present arrangement. ;D ;D Sue
Post by seeshell on Nov 27, 2012 10:29:31 GMT 10
Hi Donald80 How nice that the Cowra experience (next to Anne and Graham) in the other park rubbed off on you - you're in now! Welcome to vintage vanning! Cheers Seeshell (Anne and Graham's Daughter In Law)
donald80
warwick q.l.d.
Post by donald80 on Nov 27, 2012 19:04:55 GMT 10
on further looking have found under a bracket in frount of the no i have found the letter i believe to be R with a hole drilled threw the centre makeing it R286 .the main chasie is of C se ction with angle ion cross section the only other van like it is a vacation any more thoughts. don
Post by JBJ on Nov 27, 2012 19:13:57 GMT 10
Hi Don & Jane,
Good to see you got the computer working. I'm sure you will sort this number thing out.
Its been great catching up with you guys at the last couple of events, & we will see you soon ( hopefully ) at more.
Dennis & Sue
Post by Franklin1 on Nov 28, 2012 13:04:23 GMT 10
G'day donald80, I've been mulling over your van a bit more, and obviously the "R" prefix in the chassis number means something. I had a look through the Index in the Down History Lane section, and out of all the 'R' names, the only one that comes close might be the ReLax brand. If you click on this link and scroll down to the bottom to the last van, and compare the look of this van with yours. There are some similarities with the shape of the front, but not enough overall to convince me your van is a ReLax brand. If your van is not a ReLax van, then it'll be another name starting with "R", I reckon. cheers, Al.
Post by Deleted on Nov 28, 2012 19:23:30 GMT 10
Hi all, I reckon you are on the money Al,looks like a Roma to me,which as we know have been re branded quite a few names over the years! Cheers hughdeani
donald80
warwick q.l.d.
Post by donald80 on Nov 28, 2012 21:10:02 GMT 10
hello franklin 1 and the good folk who came on board SEASHELL has it right it has got me in. Al a bit more info.that might help. weight 920 k.g. two anda quater inch ball air over hydrolic brakes rego. labels on the window were victoria 82---83 could pick up letters indicating franklin there could have been a shelf above the sink on the left hand side of the small window there are three screw holes in the lamate there. i had a look at the relax caravans and the pathfinder i don't think it is either. thanking all for your intrest Don
donald80
warwick q.l.d.
Post by donald80 on Nov 30, 2012 6:10:35 GMT 10
g'day to Franklin 1 after hours of looking through threads i have found caravans that look similiar so here i go_______ in Franklin1 thread 28-9-2009 you show a 1960's panorama looks close has the two power plugs on the frount wall behind the gas cylinder ----the back window looks rigkt----outside light in the right place ----windows o.k.-----does not have the small window above the sink as i note very few franklins has ihis window my van does have this window-----my van has a very narrow door just ouer 17 inches the other van very similar is the 14ft.6in.regent looks the same only mine has only one draw in frount of the sink where this shows two draws.as you were looking for a van name starting with R could this be it.at the moment i cant come up with any thing else. cheers that's all i have to report Don
donald80
warwick q.l.d.
Post by donald80 on Dec 13, 2012 10:19:14 GMT 10
g,day to all has AL gone on hohidays or my computer has gone n the blink i thought i might have had a few results by now however i now pulled the back out of the van and found under the al sheeting the original tempered masonite sheeting don
Post by Franklin1 on Dec 13, 2012 15:28:03 GMT 10
G'day Don, I haven't replied because I've run out of ideas about what brand your van might be. You might have to resort to making up a brand name yourself...maybe call it a "Ranklin", which is sort of like a Franklin but has a chassis number starting with 'R'. cheers, Al.
donald80
warwick q.l.d.
Post by donald80 on Dec 14, 2012 13:53:55 GMT 10
thanks Al for what it is worth it may be home made incorpating or copying other designs thanks for your help have a nice a Xmas Don
donald80
warwick q.l.d.
Post by donald80 on Dec 24, 2012 20:46:44 GMT 10
help can't anyone come up with anything new--------------------- i still think after many hours of reading and looking at all the old photo's that it could be a 1959 franklin or there obout .well it's xmas eve so have a great day tomorrow.
donald80
warwick q.l.d.
Post by donald80 on May 5, 2013 17:18:49 GMT 10
a fair amount of time has pased since the last posting the old van is looking great with a compleate new back half the frount and all timber that has showen rot replaced the roof painted with a insolating paint painted inside and out still have curtins and kitchen seats com. bed to make and cover. would like to put photo's up but still can't work out photobucket i can send with picasa if anyone can come up with an i.d.thanks to all don
