tonyh
"Dolly" 1967 Riviera
Post by tonyh on Mar 5, 2008 22:35:54 GMT 10
Hi All, I had no luck locating new rubbers for my 1967 Olympic with O.Baker & Son windows so I am having the die made and after calling a number of manufacturers (who weren’t too nice) I have found one who I have had discussions with about doing a test sample then a "run". I presume this rubber wasn't exclusive to one window manufacturer so it might be of use to the wider caravan community, Sunliners looks the same and according to lazza maybe Roadmaster. If anyone is interested you can send me a PM or e mail so I can see what amount I might need to add to my order. They are still working me out the quote and the minimum run so I don't know how much yet. Whatever it costs I don't have much option other than replacing the windows which is too expensive and I want to keep the originals anyway. If there are other "special" rubbers that anyone might need send me a PM or e mail and I will see if I can get enough volume to make a die and do a run. This is a cross section that slides into the aluminum frame and seals against the body when the window is closed. Cheers, TonyH.
Post by atouchofglass on Mar 6, 2008 17:11:35 GMT 10
Greetings Tonyh Is this the rubber holding the glass in? If it is count me in. I need to do all my windows. Will it be in black or grey?
If it is rubber sealing the aluminium against the fibreglass. Ie when pulling the window frame completely out and resealing it into the fibreglass hole it came out of.... I am using mastic and then sealing the aluminium edge all around so no water has a hope of getting between the fibreglass and aluminium frame. This is the way it is done on boats. Including luxury yachts.
Atog
tonyh
Post by tonyh on Mar 6, 2008 20:15:27 GMT 10
Hi Atog, Yours is a 1968 - the windows are different, as you say you just seal the outside frame, on the early models this rubber does the sealing against the fibreglass when closed. The rubber you need to hold the glass tight is available from your local friendly glass repairer - when I did all the windows in my 1974 Viscount I took a piece of the old rubber and matched it up - they have heaps of different types and pretty cheap. Only comes in black though, which I wasn't happy about but when they were all done it looked good. A word of warning - It is worthwhile sliding the inside part of the window out, dismantle, checking the corner stakes for damage, cleaning the aluminum that the glass rests against, because if you just replace the rubber there might be some corrosion on the frame which will distort and probably brake the glass when you fit the new tight rubber. Cheers, TonyH.
Post by atouchofglass on Mar 6, 2008 20:17:59 GMT 10
Thanks Tonyh All good information taken and used ;D ;D Atog
Post by humpty2 on Mar 8, 2008 12:23:45 GMT 10
Tony , if you can get some of this section, it will solve a lot of problems for owners of Sunliners and any van owner with "Qualcraft" windows........me too! Off line for 3 weeks now....off to Mt gambier ;D
Post by chris foster on Mar 17, 2008 19:26:53 GMT 10
Hi Tony I am very interested in new rubbers for the sunliner windows I have 8 windows to re do and ii have looked around without any luck. you can contact me on my mobile 0428655566 thanks looking forward to talking to you ... chris (fozzie)
Post by bratso on Mar 18, 2008 9:05:16 GMT 10
hi tonya i to have the same baker windows in my two glassies so could be interested i just need to do some measurements i think a lot of different vans had those windows .. alan b
tonyh
Post by tonyh on Mar 29, 2008 22:22:30 GMT 10
Hi All, Getting close now as we are down to final drawings (BELOW) to make up the die and will do a "trial" run to check in the window frame - lead time is about 4 to 5 weeks. Once I do the checking and they do any "tweaking" to the die the first run will be 200 metres and should work out to about $8.00 per metre. I have had a great response so everyone that contacted me, please let me know if you are interested and how much so I will see if I have to increase the first run. Cheers, TonyH
Post by chris foster on Mar 30, 2008 19:29:40 GMT 10
Hi Tony I will take 17 mts of rubber if thats is ok ....thanks .....Chris
tonyh
Post by tonyh on Mar 30, 2008 20:18:24 GMT 10
Hi Lazza and Chris,
Your now both on the list. I will let you know ASAP on delivery/payment. As I only know the rubber will fit my window for sure, will you guys need a sample to check fitment?
TonyH
Post by fozzie on Mar 31, 2008 19:18:39 GMT 10
Hi Tony I have a couple of pieces of rubber that I might be able to send you to check if this is the right style please let me know as i live up on the Sunshine Coast and it is'nt that far to travel or post to Brisbane ......... thanks ........Chris
Post by bunky on Apr 2, 2008 6:42:08 GMT 10
Hi It would be great if i could order 8 meters for a 60's sunliner. I could send you a sample to check Lynda
tonyh
Post by tonyh on Apr 9, 2008 16:54:36 GMT 10
Hi All, Getting close now, I put in the "official"order and the die is being made and hope to have the test run in about 2 weeks (approx 1 metre) so I can check it in the frame and then the full run 2 weeks later all going well after any adjustments are made if necessary. - I will let everyone know ASAP Cheers, TonyH
tonyh
Post by tonyh on Apr 9, 2008 22:55:05 GMT 10
Hi All, I changed the heading because I have just received a sample of rubber by Lynda in Cairns from her Sunliner with qualcraft windows to check to see if it matches my sample out of my Olympic and it Does!!!!! ;D It matches and fits in the aluminum frame beautifully. I am waiting on other samples from "other" makes of Vans and windows to see what else we can match up. I will keep you informed as I go. Cheers, TonyH
Post by apiarist1 on Apr 13, 2008 16:58:52 GMT 10
Tony
I'm restoring a sunliner withqualcraft windows, and would love to get 8 metres of the rubber profile.
Apiarist 1 (Arthur McCulloch 0249342334). Let me know if it goes ahead, and where I can send some funds to.
Regards
Apiarist1
tonyh
Post by tonyh on Apr 23, 2008 22:13:10 GMT 10
Hey Everybody, ;D Just an update - I have been shown the "first" run of the new rubber and we are doing some "tweaking" of the die to get the shape as near to original as possible. Rubber is unique in that unlike other products the die shape does not give you your finished product sizing and you keep modifying the die after each test run to get the desired shape and size. The run I was shown was after a few test runs and a number of e mails and trips for discussions - no wonder other people I spoke to didn't want to do this job!!! Once the rubber has been vulcanized it can't be chopped up and put back into the mix like plastic and other products, it is waste. The only good part is that when we do the "final" run next week and the die is finished (hopefully) we can do a run anytime and the finished product will be the same as the previous run. ;D Cheers, tonyh.
tonyh
Post by tonyh on May 1, 2008 22:16:59 GMT 10
Had a look at the second run on Tuesday and I was very impressed, they have got it very close - or am I just being picky? They are going to do another run on Friday or Monday after the die maker does his magic. Once I am happy I will send samples to all who have ordered so you can be sure it fits your windows before sending your order. tonyh
Post by willyn on May 1, 2008 22:39:13 GMT 10
Gidday Tony h I havent got any internal photos of JFK (my Kennedy)however I will take some and post them for you this week Will
Post by apiarist1 on May 3, 2008 18:37:41 GMT 10
Tony
Count me in - send a sample to 52 Belmore Rd, LORN, NSW 2320 - let me know the postage and I'll either reimburse or pay in advance.
That's great news - was looking forward to sveral nights fine tuning the stuff available from Clarkes Rubber
Regards
Apiarist1
tonyh
Post by tonyh on May 4, 2008 7:13:26 GMT 10
Hi apiarist 1, Will do. I'm not worried on the initial postage as it will only be a small sample and will fit in a standard envelope. cheers, tonyh
Post by fozzie on May 7, 2008 19:11:33 GMT 10
Hi Tony I will be in Brisbane next Sunday and also later next week if you can ring me on 0428655566 with your phone no or address I will contact you thanks .... chris
tonyh
Post by tonyh on May 16, 2008 23:01:11 GMT 10
Hi Everyone, - hang in there a bit longer - the manufactures have been waiting for the correct type of raw material to arrive - and it has, today . So with any luck I can check the sample next Wednesday since the die maker has spun his magic and we can finally get this show on the road ;D
Post by apiarist1 on May 22, 2008 16:47:38 GMT 10
Good news.
You've done wonders here. Look forward to a sample
Apiarist1 (Arthur McCulloch)
tonyh
Post by tonyh on May 23, 2008 20:16:32 GMT 10
Well,,,,,,,,,,,,,,,,I picked up the new rubber sample today and it looked perfect, and a good snug fit but when I tried to fit a full length it was too tight at the bend in the frame because when they bend the aluminum frame to make the window it compresses the "T" slot for the rubber. So on Monday they will look to do the final (I hope)"tweak" of the die and run a sample on Tuesday. Will keep you all updated.
Post by fozzie on May 24, 2008 18:30:47 GMT 10
hi tony, sounds great just cant wait to see the caravan with new rubbers .... cheers .... chris
