Post by Geoff & Jude on Apr 19, 2009 12:18:40 GMT 10
hi all got this info from a caravan mag, thought it may be of interest. then there was this info on stabilizer bars - might change some myths that are out there about spring uplifts and airbags.geoff 'n jude
Post by cobber on Apr 19, 2009 14:58:52 GMT 10
G'day geoff and Jude, That is all good information to have under our belts. It means that if we go to the weigh bridge with the 'van empty and they don't ask you to disconnect 'van from car what you are getting is not the GTM... or the ATM... or the TARE weight. I don't know if that is what generally happens but it is what happened when I had Ol' 36 weighed. NSW Rego refers to GVM, that I take it is the same as ATM As most vintage 'vans don't have a trailer plate stamped with either ATM or TARE stamped on them it is probably wise to make sure the 'van is weighed properly.... i.e. disconnected from the car. When did trailer plates come into vogue Cobber.
Post by Deleted on Apr 19, 2009 18:27:51 GMT 10
Cobber..
If you go to a weighbridge to weigh your van and they dont ask you to disconnect your van and drive the car off the weighbridge... well.. they just arent doing their job.
I would also defy anyone who owns a caravan... be it vintage or otherwise to guess within 50kg what their "Person Load " is.
As we all know , we of the vintage caravan faith are "Collectors and gatherers" adding little bits and pieces as we travel around the countryside. We do not have a set of scales to tally up all the .. junk....... ooooops .. collectables/ necessitys that we tend to ferry into our vans over the years and you might be surprised to see just how far over the GTM you just may be.
Reddo
Post by cobber on Apr 19, 2009 19:14:40 GMT 10
Post by Roehm3108 on Apr 20, 2009 21:12:49 GMT 10
