Post by ralphy on May 3, 2008 15:17:49 GMT 10
would like to know what sort of rims and tyres a 62 sunliner runs on as the ones on it at the moment are cactus. will be travelling from the sunny coast to Taree to pick it up would like to be prepared to save time as i want to get a pink slip on the satuarday to tow it home any information would be greatly appreciated cheers Ralph.
Post by humpty2 on May 3, 2008 18:35:56 GMT 10
Holden 13" will do the job.......I think the stud pattern is the same on all 13".........the main variation is that some are rivetted and some are welded. If the van has after market electric brakes the rivetted rims may not clear the brake drums. Regards.......Humpty.
Flattop
Kowabunga!
Post by Flattop on May 6, 2008 9:48:45 GMT 10
would like to know what sort of rims and tyres a 62 sunliner runs on as the ones on it at the moment are cactus. will be travelling from the sunny coast to Taree to pick it up would like to be prepared to save time as i want to get a pink slip on the satuarday to tow it home any information would be greatly appreciated cheers Ralph. All 13" Holden wheels have the same stud pattern from '56 up (HK 14" wheels share the same stud pattern). The difference is in relationship to brakes. If HR style brakes are fitted (wider) then the later wheels need to be used to allow correct fitting of wheel to drum (wheel centre will distort drum and not allow correct tensioning of the wheel). eg early brakes = early or late wheels Late brakes = late wheels. These are identified by a single hole (~3/16"), drilled in the centre on the rise for the wheel cap) Hope this helps.
Post by ralphy on May 7, 2008 16:03:28 GMT 10
thanks/ once again this site provides the information, so i take it the later wheels would be the safer bet??? oh and are radials okay or do they track differently to cross ply's?
Post by JBJ on May 7, 2008 17:56:26 GMT 10
Hi Ralphy,
I dont really know if there is any difference.
I have run cross ply on the last 4 vans I've had, after being told by a guy I respect that they really are the better tyre for a van. I will continue to run cross plies on all my vans I rebuild.
My Sunliner runs 6" wide Torana 13" wheels, with 6.40x13" 6 ply Indian tyres. I've towed it around 10,000 km in the last year or so. It doesnt sway or wobble, & I've towed with 2 different vehicles. It tows great up to 120KMH when overtaking, so I'm happy with the cross plies.
Other guys run radials, & reckon their van tows great. Again I dont know if theres much difference, but I haven't bothered to try both on the same van to see if there is a noticeable difference. Jailbarjuice
Post by fozzie on May 7, 2008 19:25:40 GMT 10
Hi Ralphy I do have a spare set of rims and tyres that you are welcome to use where on the sunny coast are you if i can help please ring me 0428655566 and I can arrange something with you ..... chris
Post by humpty2 on May 7, 2008 19:38:10 GMT 10
My Sunliner is running on radials.....retreads at that! Towing from Newcastle to Mt. Gambier and back again I never felt the van was doing anything but following the car. I tow at about 90klms per hour and anyone having towed a Sunliner will tell you it tows like a dream............. even reddo! ;D ;D I think the radial / crossply difference would be more pronounced on a large and heavy caravan.
Post by Deleted on May 8, 2008 7:37:43 GMT 10
Humps wrote. "I tow at about 90klms per hour and anyone having towed a Sunliner will tell you it tows like a dream.............even reddo! " Very true.. S#n#i#e#s do tow well. I tow at the speed limit.. 110KPH where permissible .I had a stint of about 5ks at 75 MILES PER HOUR . along the Hume Hwy towing Hillbillys sunliner to MT G. Tyres on the van where 6.40 X 13s crossplys.. No load levelers/sway bars. Never had a swaying moment on the whole trip. Reddo.. Not going soft in my old age.. Bondwoods are best ya know.
Post by ralphy on May 11, 2008 18:12:29 GMT 10
once again l must say the feedback you get on this site is awsome,fozzie has hooked me up with some rims so all should be well!!!!, cant wait to be educated on all that is EH as im a blue oval man just gotta love all that is classic!!!!By the way the way Jailbarjuice whats under the bonnet?? anyway will keep you all posted on the big adventure with photos when l can so till then thanks and good luck to your famies!!! cheers Ralph.
Post by Koala on May 11, 2008 19:06:06 GMT 10
jailbarjuice whats under the bonnet?? cheers Ralph. Ummmmmmmm.......................he doesn't have a bonnet........LOL ;D Koala
Post by JBJ on May 11, 2008 19:29:22 GMT 10
hi Koala & Ralphy.
I got a bonnet, its sitting in the garden as a bit of yard art.
The engines a Ford Windsor, bored & stroked to 426 cubes, or just under 7 litre. Its got all the good bits I could buy when I built it in the late 80's. It didn't get used until 2000.
Its set up with a pretty low tune, & idles along nicely.
I had clutch problems with the recently fitted Tremec 5 speed, so I just spent another bucket of loot putting in a new clutch, pressure plate, re-machined flywheel, re-aligned clutch linkages, new rear wheel bearings, reconditioned diff with new 4.11 gears( changed from 3.5)
I also finally got the leaking sump ( from the trip to Morgan a couple of years back) fixed properly, & put a new accellerator pedal & cable in.
Its like driving a different car. The clutch is softer (replacing the identical parts removed), & the accellerator is much easier, & I've finally got full throttle. It revs out to the rev limiter in first, second & third without any effort. Thats as fast as I want to go on the road, & just a tad over the speed limit.
Its all fun. Better than being normal.
Jailbarjuice
Post by ralphy on May 13, 2008 21:03:31 GMT 10
Geeeesus!!!! Jailbarjuice, ill bet thats handy when ya dont want the missus to change the station on the wireless. Bet its even funnier when shes puttin on the lippy eh? ?? Its all fun. cheers Ralphy.
Post by JBJ on May 13, 2008 21:30:23 GMT 10
Hi Ralphy,
Boots wears cotton wool in her ears when she travels in the rod. Dont worry me cause I'm near deaf when I drive it.
Jailbarjuice
