Post by will and lyn on Apr 14, 2007 9:22:50 GMT 10
here are a couple of my old vans that I have done up for any newbys on the site that is Trevs Tram and it was around the 49 50s mark full aluminium body extremely heavy old van but quite unique inside and out img.photobucket.com/albums/v633/billyn/P5250005.jpg[/IMG]another 70s van I will post these and contnue in the next post as good old crapbucket sometimes works and sometimes doesnt before I lose the lot Will
Post by will and Lyn on Apr 14, 2007 9:52:23 GMT 10
continuing with Trevs tram before inside fun restoration 1950 ali van looked like a melbourne tram and towed like one Will
Post by will and Lyn on Apr 14, 2007 10:10:24 GMT 10
;D ;D OOOoops I left one out tribute to trevor Roberts this is one reason why if you spend 200 hours restoring a van and around $3500 you should insure your van (incidently this is why I think Jailbars van is worth every cent of $5000,00) Two hundred hours labour for elvis and $3500 makes it worth around ten thousand dollars the life and death of Elvis this is for the newbys most of you have seen Elvis and probably sick of seeing it but two hundred hours restoration in a heat wave around 35 to 40 degrees I suffered man and Im getting the most out of it Will PS the fire was hotter than 35 degrees it scinged my eyebrows from 10 metres Will
Post by jnigrelli on Apr 14, 2007 10:33:01 GMT 10
was the fire set by the recipient of the "one finger salute?"
if so, i'd say it were he with the bigger finger.
Post by firefighter on Apr 14, 2007 10:34:37 GMT 10
