Post by avoash on Jan 14, 2023 17:59:04 GMT 10
Hi can someone please explain to me how to replace the fixed rear glass in a 1988 oxford.i have removed the plastic strip that goes inbetween the rubber on the outside of the caravan,but that is as far as can get,there does not seem to be be enough slack in the rubber to remove the glass.The caravan can not be moved,so I need to get the glass out in one piece to use as a template for a new piece Any help would be hugely appreciated,thanks Ash
Post by hughdeany on Jan 15, 2023 8:19:23 GMT 10
Hi and welcome Ashh, Are you from NZ or UK? We don’t have Oxford vans here in Aus,maybe a local site woukd be able to help you? Cheers hughdeany
Post by avoash on Jan 15, 2023 11:37:44 GMT 10
Thanks for your reply.I am in NZ and the caravan is non movable on a remote piece of land,so I need to get the glass out and take it with me to get a new piece,thanks again Ashley
