Post by bennysimm on Sept 26, 2022 11:29:19 GMT 10
Hello, I have a 1969 Viscount Royal(14 Foot) and it's got the old style Marconi track for the awning. I was seeing whether anyone had a 10-11 foot awning to suit this track as I want to keep caravan original as possible. Thankyou. Attachments:
Post by cobber on Sept 26, 2022 19:13:04 GMT 10
G’day bennysimm, I don’t know if my old eyes are seeing that photo you posted properly but, it doesn’t look like the Marconi track I’m familia with. This is the Marconi track as I know it. And these are the slides that fit that track. Is your track the same as the one above ? Cobber.
Post by bennysimm on Sept 26, 2022 20:27:54 GMT 10
Hi Cobber. Sorry for some reason my photo I uploaded isn’t clear, but that’s the correct track. It’s approx 20mm wide. Struggling to find either the clips or full awning.
Post by Mustang on Sept 27, 2022 7:12:54 GMT 10
Hi bennysimm, There is a guy on another forum that has made his own, I will send you his contacts. Cheers
Post by bennysimm on Sept 27, 2022 7:40:25 GMT 10
Thank you Brent. Hopefully we are able to source to keep our caravan original.
Post by bennysimm on Sept 27, 2022 9:18:07 GMT 10
Hey Cobber, Thank you for your response, I just measured and I have the 17mm wide track. Are you able to assist with these? We have always intended keeping it original, even if it means a lot of work sourcing what is required.
Post by cobber on Sept 27, 2022 9:22:06 GMT 10
G’day bennysimm, The track (and clips) are available in two sizes so your track will be either 17mm or 22mm wide. If it is the larger size I can provide you with the larger clips albeit without the backing bit that is easy enough to make up. We have a thread about Marconi track & clips url= vintagecaravans.proboards.com/thread/9506/annex-awning-fasteners]HERE[/url] might give you a few clues 😉 I’m really pleased you intend keeping your beautiful van original 😀 Cobber.
