Post by nev360 on Jan 11, 2021 4:06:26 GMT 10
linkHi is this a Franklin any info would be fantastic Thank you
Post by nev360 on Jan 11, 2021 4:14:08 GMT 10
sorry cant seem to upload photos
Post by nev360 on Jan 11, 2021 4:23:14 GMT 10
Post by Don Ricardo on Jan 11, 2021 21:01:10 GMT 10
Hi Nev360, Welcome to the forum. From what I can see of the van in the photo, it isn’t a Franklin. Franklin didn’t produce any vans with the “leaning forward” style of front above the waist line. You can see some typical Franklins if you click here. If you can show us some more photos, including the front and the rear and inside, we can probably identify the van for you. Regarding posting photos on the forum, you can find some instructions here. The simplest way is to use the ‘Add Attachment’ button at the top of the ‘Create Post’ window. But if you look at the Flickr instructions you will also see how to post photos directly from Flickr using their URL. We’d love to see some more photos of the van, so please do persevere with posting your photos. Don Ricardo
Post by nev360 on Jan 14, 2021 0:24:22 GMT 10
Is it maybe a skyline by franklin
Post by Don Ricardo on Jan 14, 2021 16:53:10 GMT 10
Hi Nev360,
Skyline and Franklin were separate and independent manufacturers. However, in the early 60’s, Skyline did begin to sell vans sourced from other manufacturers under the Skyline name. One of the sources was indeed Franklin, but those vans pretty much looked like Franklins, just with a Skyline badge on them. Further, they still retained the Franklin serial number.
That means that if your van doesn’t look like a Franklin - which it doesn’t from the photo you’ve shown us - then it won’t be a Skyline badged Franklin. But it is still possible that it’s a Skyline.
Do you have a particular reason for thinking that the van is either a Franklin or a Skyline?
If you’re having trouble posting some more photos, you’re welcome to email me some photos and I’ll post them for you, and then we can work out who might have built the van. My email address is caravanhistory@gmail.com (but let me know here when you’ve emailed the photos).
The other thing that may help us in identifying your van is if you can tell us if there is a serial number welded (or created out of weld) on the drawbar of the van? That might tell us what we need to know.
PS Sorry, the links I gave you in my earlier post didn’t work. I’ve fixed them now, so they’ll take you to the threads I intended.
Also, I’ve inserted your photo into your first post so that people can see it without going to the link. Hope that’s ok?
Post by Don Ricardo on Mar 12, 2021 15:33:13 GMT 10
Hi all, Nev360 has provided some more photos of his van in the hope that we may be able help him identify it (see also photo posted by Nev360 higher up this thread): As you'll see from the posts above, Nev360's thought was that the van might be a Franklin or Franklin-built Skyline. Interestingly, the van does have the "Franklin shelf" in the galley, ie the little shelf with the single central support which is often a give away feature of a Franklin. In addition the textured ceiling and sliding-door overhead cupboards were used by Franklin. However, the shape and external features of the van do not fit any model Franklin, nor any model Skyline, including any of the Franklin-built Skylines. In addition there is no Franklin format serial number on the drawbar, so my conclusion is that Nev360's van isn't a Franklin. The ceiling material and the overhead cupboard style was used by several of the other Ballarat-based caravan manufacturers in the 1960's, and I am therefore wondering if the van was built by another of the Ballarat firms? The van is most similar to some of the caravans built by Coronet, so perhaps that's its origins? In contrast it also has some similarities to some Roma vans. Can anybody throw any more light on the question to help Nev360? A couple of other observations: The van has had some modifications made to it at some point. The door is not original, and nor is the hatch. Further the flashes on the side are similarish to those used by Judd & Innes on the vans they sold, including those branded as Customlines.
There is also a plaque on the front of the van above the windows which says 'A D'. I've had a look at the plaque in another photo and it is quite short, and I can't see any signs of any letters other than the 'A D'.
I'll look forward to reading your comments. Don Ricardo
Franklin?
Apr 17, 2021 0:56:52 GMT 10
via mobile
Post by vickivanning on Apr 17, 2021 0:56:52 GMT 10
I’ve got a coronet that looks very similar although cupboard style is different. Could it be a coronet rebadged as a Roma? I was told mine was a 1978 Coronet Princess (diner at left, double door wardrobe and couch folds in to double). No wrap around windows so a standard model rather than ‘deluxe’?!
Post by Roehm3108 on Apr 19, 2021 8:02:43 GMT 10
Not too sure if this helps or not DonR. The AD intrigues me, despite your comment that it is a short sign. You may have the benefit of seeing a larger shot of that sign?? The thought that did strike me is that perhaps the AD is the end of the name NOMAD? You may recall under the HillanDale thread in the DHL section that Nomad "adopted" their vans as their own. I notice that nev360's van has plywood sides and there is no indication that the earlier Hillandales may also have had plywood sides. That they may have, shouldn't be discounted. Perhaps Nomad also adopted Franklin caravans? It's interesting that hughdeany hasn't weighed into this topic!!!
Post by hughdeany on Apr 19, 2021 18:48:28 GMT 10
Hi all, Just spotted this Roehm! Looks like a Huntsman to me,with a trimatic door and 4 seasons hatch fitted sometime in the seventies. I agree Don that it’s a Customline flash too,the originals were painted,but this one looks like a sticker. Other than that I have no idea! Cheers hughdeany
Post by Don Ricardo on Apr 19, 2021 22:37:50 GMT 10
Hi Roehm, That's an interesting thought about the Nomad. Here's the photo that led me to say that the sign on the front of the caravan was quite short. Of course part of it may have broken off, although there seem to be a screw at each end which suggests not? Early Hilandales did have bondwood sides, so that is a possibility, but it doesn't sound as if Hughdeany thinks that Nev360's van is a Hilandale. Don Ricardo
Post by Roehm3108 on Apr 20, 2021 7:12:00 GMT 10
I see what you're saying DonR, plus, now that I look more closely, the sign seems to be centred as it is. Makes you wonder about who calls their van AD, unless they're a keen tennis player
Post by Don Ricardo on Apr 20, 2021 10:10:35 GMT 10
Hi Roehm, Yes, the sign looks centred to me too. Perhaps they were trying to date their van and couldn't get any closer than AD - Anno Domini? And you'd have to say that is correct! Don Ricardo
Post by Roehm3108 on Apr 21, 2021 7:37:30 GMT 10
Aaahhh. but does it qualify as "vintage" ?
