Post by frankidownunder on Aug 8, 2007 22:12:34 GMT 10
Hi all, Just thought I might put a few pictures up of some of the rot I found in franki, my Franklin Caravelle. ![:-[](//storage.proboards.com/forum/images/smiley/embarrassed.png) I have since cut out the damaged areas and re built them ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) .also replaced inner sidewall, installed insulation , plus sisalation and refitted skin. The rot is not very evident except for loose screws outside and water stains inside, however once the outer skin came off..... ![:-[](//storage.proboards.com/forum/images/smiley/embarrassed.png) Still have Rh side to do (probably as bad) ![:-[](//storage.proboards.com/forum/images/smiley/embarrassed.png) but should be good when finished. I will post more photos later (when Primus speed up my connection again.) ![](http://i22.photobucket.com/albums/b330/Wright3350/15RotinLhfrontcornerlower.jpg) ![](http://i22.photobucket.com/albums/b330/Wright3350/20CloseupoftopLhcorner.jpg) ![](http://i22.photobucket.com/albums/b330/Wright3350/14RotinLhfrontcornerupper.jpg) Hope this is of help to some of you with your restorations. Frankidownunder.
Post by Franklin1 on Aug 9, 2007 9:38:55 GMT 10
Frankidownunder, I think your photos should be mandatory viewing for all newer prospective vintage caravan purchasers. I have a similar situation with my Franklin, and I now explode with mirth when I read descriptions of vans for sale as being in "good condition", and highly priced. It is not until you strip back the "covers" that you see what really lurks underneath. Newer enthusiasts would do well to remember that any "beauty" you see on the outside, may truly only be skin deep. And I don't mean to turn anyone off buying a van, but please do consider potentially hidden damage that will require attention, and adjust your valuation of the van accordingly.
Al.
Post by Roehm3108 on Aug 9, 2007 17:46:50 GMT 10
Great pics. I agree, this should me mandatory viewing for all buyers of VV's. Makes you wonder how it stayed together!!!!! ![:o](//storage.proboards.com/forum/images/smiley/shocked.png) But, it makes us better restorers of these treasures, and in the end we know how it all works! Ray
Post by humpty2 on Aug 9, 2007 19:52:25 GMT 10
Never came across this problem restoring Fibreglass vans! ;D ;D ;D
Post by Deleted on Aug 9, 2007 22:08:20 GMT 10
Ho Ho Humpty Ho Vvvvveeeerrrryyyyy Funnnnnnnnyyyy ![:(](//storage.proboards.com/forum/images/smiley/sad.png) Onya 2 heads e---POXY....... has its own side effects ![:P](//storage.proboards.com/forum/images/smiley/tongue.png) Reddo- C/- RSPBCA
lulu
Post by lulu on Aug 10, 2007 18:10:38 GMT 10
You read my mind Humpty ![:D](//storage.proboards.com/forum/images/smiley/grin.png)
Post by tinnie on Aug 10, 2007 23:09:28 GMT 10
Ok you fiber-glassers. Mean to say never had rot any timber under the layer of glass??? ;D
Seriously, these pics are a big lesson to newies out there. I have seen plenty of older vans for sale on ebay that boast a 'fresh paint job'. Rules are a bit like an old car, fresh paint usually hiding something. And like my franklin egg, the photos I was given showed none of the very-evident rot. Either the seller was not very observant or had selective vision. Fortunately I bought it cheaply allowing for such things..... Good luck with the resto Franki, it really looks like a fairly solid base!. Anyway it's well worth it, it's a Franklin after all! Cheers, Gristy
whippy
![*](//storage.proboards.com/forum/images/stars/star_lavender.png) ![*](//storage.proboards.com/forum/images/stars/star_lavender.png)
"Twiggy" the Globetrotter
Post by whippy on Aug 11, 2007 20:10:16 GMT 10
You have got me worried, there are signs of a leak on the rear driver side on the Franklin Caravelle. I have to replace the Draw bar & now this worry !!!!!! My god what have I bought ![???](//storage.proboards.com/forum/images/smiley/huh.png) ![???](//storage.proboards.com/forum/images/smiley/huh.png)
Post by frankidownunder on Aug 11, 2007 23:42:24 GMT 10
A Franklin,
the best you can buy. (read gristy's avatar, it says it all.)
whippy
Post by whippy on Aug 13, 2007 19:21:44 GMT 10
I am very happy with the Franklin, it was a tongue in cheek comment ![:'(](//storage.proboards.com/forum/images/smiley/cry.png) Crikey it only cost me $662.00 to buy I have several questions :- 1. How do I take the cladding off? 2. What is the timber used in the frame? 3. Has anyone used the epoxy sealant used in houses to seal suspect rotted timber? 4. The ceiling plywood at the rear is damaged & I want to replace it. Does it go to the outer walls or finish at the cupboards?
