Hi Don
Although most people dont consider brush painting to be all that difficult.. and it isnt if all you are doing is painting the side fence.
There is definitely a few tricks of the trade that can mean the difference between an almost spray coating like finish and a finish that looks like it has been done with a rake.
Surface preparation. clean , smooth and free of grease, silastic, oily fingerprints and dust.
Undercoat .. apply evenly and treat it as if it was the finish coat. if ya can see brush marks in it .. then you will see brush marks in your top coat . best to undercoat and give it a chance to dry and then give it a light scuff with sandpaper before dusting off and applying top coats.
top coats
Pick a warm sunny day and stick the van out in full sun to warm up the surface.
Dont try and paint when there is a lot of moisture in the air.. like early morning or late arvo.. or... raining . Even if the van is under cover the paint will " suck in" moisture and your "Gloss finish " will end up blushing and looking like an old school blackboard.
Another trick is to stand the paint tin in hot water.
This warms and thins the paint which helps to make the paint flow on evenly and level out without brush marks.
Mask up and Use a good quality brush to cut in around the door , hatch and windows. You can choose to roll the rest of the paint on . Again use a good quality short napped roller and apply by cross thatching then finish with long even strokes going "with the grain".
If you brush the van use a good quality brush that isnt gunna shed hair or bristles on every stroke. Give it a couple of coats. Again allowing the paint to dry thoroughly between coats and lightly sanding and dusting off between coats to get rid of any lumpy brush marks before applying the next.
When applying the top coat try and "lay off' with the brush as you finish each section.
By "laying off" i mean lay the brush over on an angle and dont apply any weight to the brush. End result should be near as good as a spray job.
Paint.?? Others will argue but i have been saying for years "Oil based enamels" Gives a car like finish. easy to wash and comes up shiney.
wash up in mineral turps.
Rollers" you can buy them in 3 packs. they are cheap so by about 3 packs of them. when you are finished doing as much as you can for the day. just thow em in the bin. You can waste a lot of turps trying to get a roller spotlessly clean. Just use a new roller each time you attack the van. lot cheaper and a lot less messy.
Brushes arent so bad just fill up a one litre tin with turps and stand your brushes in there.
Make sure you clean em up thoroughly when changing from one colour to another. Remove aqll excess turps from the brush before kicking off with the next colour or coat.
Best done by flogging the brush backwards and forwards on the nieghbours fence of some other sacrifical area
The side of the dog is always good
.. and it makes a change for the kiddies . they just love lime green cattledogs ;D
If you seen the side of my shed you would think that "Ken Done" had been practicing on it.
Having said all that . you would think the TD i built and painted would be perfect ... well it aint. I done a lot of painting after work at night in the shed, under fluro light, tired and cranky and the whole thing looks crap.
Mistakes?? .. tear-arsing, laying on too much paint, working at night under artificial light. The list goes on... But hey it sure looks like its 50 year old now.
last words of advice
Disposable paper overalls are the housewives friend.
Watch ya dont stand in the paint tray when rolling.
Dont lean on wet paint.
Dont leave a brush and paint sitting on the ground unattended. Kids never miss an opportunity to "dabble" in the art of painting when your not around.
Dont kick the tin off the top of the ladder....
I have done all of the above... and anyone who says they havent done at least one of these is a liar.
Oh and have a nice day. ;D
Reddo
