Windows
Apr 29, 2007 8:38:54 GMT 10
Post by wildmanaus on Apr 29, 2007 8:38:54 GMT 10
Hello All VV I have to replace the glass in two of my windows i just want to find out is the glass laminated or straight or toughened because one has perspex in it at the moment and it is going funny and the over is cracked as I locked it with the tv cable throught it. Thanks in advance Wildmanaus
Windows
Apr 29, 2007 18:47:38 GMT 10
Post by humpty2 on Apr 29, 2007 18:47:38 GMT 10
Usually just straight glass, last time I had one done it cost me $35.
its only about 3mm thick
Windows
Apr 29, 2007 19:50:26 GMT 10
Post by chippydave01 on Apr 29, 2007 19:50:26 GMT 10
Hi wild man aus, Im going to get 2 windows cut at St Marys on Tuesday.Glass is 3mm thick and costs about $35 to 40 a m2.I got a crack in one at Budgewoi and my gypsy came with one cracked .Try to keep it together by tape if it has a radius on the bottom 2 edges so they can copy the curve to save labour (cheaper price) if it breaks in pieces make a cardboard templete and take it with you .Ive been quoted $40 for glass and $5 FOR A RADIUS CUT $60 bucks total for the 2 following windows. the gypsy window is hinged from the side and slips up in this groove the fairland is top hinged Cheers Dave ..... final cost for the above 2 windows was $53.93
Windows
Apr 29, 2007 21:20:17 GMT 10
Post by wildmanaus on Apr 29, 2007 21:20:17 GMT 10
Thankyou all for your help it is great to have all yhis help on hand Wildmanaus
Windows
May 2, 2007 23:56:06 GMT 10
Post by aussietanker on May 2, 2007 23:56:06 GMT 10
Just wanted to ask yet another question ... and thought that this was the most appropriate place if anyone wanted to do a search on the same issue later ... the "rubber" seal around some of the windows in the 150 Don show quite marked signs of perishing (ok... i admit it - most of them are perished ;D)... can this seal be replaced ... if so where do i get it from and what do i ask for ... was it specific to each manufacturer? .. i also want to replace the seal around the door frame - part of it is "missing" - it looks like a pretty simple rubber seal, kind of squarish ... i presume that it would come from the same place .... is ther any particular brand that is especially better ... or worse ... than the other regards A|T
Post by chippydave01 on May 3, 2007 7:37:08 GMT 10
Hi A/T, Give spectrum rubber a call at St Marys.02 96235333 .They have most styles of rubber mouldings,only problem there not cheap but you get what you need www.spectrumrubber.com.au/Im not sure on what mould you need but most fixed windows use what is called H mould Bunnings also have the rectangle flat door seals in a foam that stick on one side Cheers Dave
