Post by Deleted on Oct 26, 2006 11:25:50 GMT 10
Hi all
I thought i would share my thoughts on wheel and tyre combos used on our old vans.
Whilst away on the recent east coast tour i managed to shred a tyre on the right side of "matilda"
The tyre was a 16x600 radial which had done a trip to Esk Qld and Morgan S.A this year plus a few short hops.. probably about 6000 miles no more than that. it was one of two new tyres that i bought from kaybee about 12 months back.
I had all sorts of hassles getting the old wheel out from under the guard and even more problems fitting the spare. Cobber and i wrestled on the side of the road outside of Gulgong for almost an hour with 4 blocks of wood and two jacks to get the wheel on .
I originally had 2 jacks packed in the van but had recently removed one to help my son like work on his 4x4 and i never replaced it.
After a bit of cussing and swearing plus a bit of good old aussie ingenuity we finally got the wheel on and made it to the van park with fading light.
Not sure how far i had travelled before i heard the wire flapping on the road and felt the vibration, as well as noticing the van "tacking" to the right slightly. at first i couldnt understand why Cobber was accelearting away from me in his stock FJ !!!!
For the next few days i searched high and low around the boondocks looking for a 16 x 600 replacement tyre .. to no avail.
Col eventually scored a 550 x 16 tyre on a prefect rim for $15 out of a property near Scone. We ended up fitting an old doubtful spare tyre to the rim with the blown tyre when we got to my place on thursday. ( thanks again for the effort Col)
The rest of the tour and Coledale saw no further problems with tyres but the issue of tall , hard to procure , scarce tyres and access to wheels on old vans stuck in my mind all the way.
So on Monday after Coledale i dug out three 15" rims that i scored off a diahatsu rocky some time back . These rims have the same stud pattern as F100 ford and suzuki 4wd. The 16" rims on Matilda are 1948 ford pilot with adaptor plates to suit the smaller yank ford stud patterns. I headed around to the tyre service and they fitted the 15's up with 15 X 195 x 70 - 8 ply light truck radials.
End result is i now have tyres which are about 2" lower in rolling diameter and about 1 or 2" wider . definitely easier to obtain if you are unfortunate enough to have a tyre blow out or destroy itself while away in areas where older odd sized tyres might be difficult to obtain. Relatively easier to fit . dont need two jacks but still need to remove the spats to get them on.
Old 16s
Fitted with 15s. You can see the difference in ride hieght. I agree that "matilda" has lost that "Vintage high heels" look . But with her new 15" joggers she sits in much lower behind the Ute and there for less likely to sway and cause wind drag.....which has got to lead to better fuel consumsion and safer towing.
And finally the biggest bonus of all. i havent got as far to fall out of / climb into the van when i am coming home/ going out after "happy hour" ;D
A lot of vans i noticed at Coledale are rolling on 1960's - 13" holden rims and tyres even these are becoming hard to find in tyre services. The days of just jumping a fence and finding a spare on that old holden in the paddock is becoming less and less common. Wreckers have bit the bullet and tossed out a lot of what they call "The old stuff".
Its OK to say "i have a spare" but what happens once you have to use it out in the back blocks and you get something a bit more damaging than just a puncture which requires a tyre replacement.
Its not a good feeling travelling knowing that your next puncture could mean a major delay in your holiday plans. Sure you can carry 2 spares but why cart the extra weight?
If you do have easy to find wheel and tyre sizes then at least check that the jack and wheel brace that you are carrying is capable of lifting the van high enough, and you do have the right wheel brace with you for the van wheel nuts. carry them under the seat in the van. The one in the boot of your car may be different.
I'm not saying go out and whip your wheels off. i'm just saying it may be wise to have a look at what shoes your old darlin' is wearing and ask yourself "what if"
Check your jack and wheel changing gear and ask yourself " does it fit,Will it do the job when asked of it ??".
Better to sort it out in your driveway than to wait for the worst to happen and have to deal with it in the middle of nowhere... with no help.. in the rain... with a nose full of flys.. a car full of screaming kids... 5 minutes before closing time at the local....
Oh stop Reddo now that really would be a horror story
Reddo - from the lower .. fatter side.
Old 16s
