Post by liam on Jul 4, 2006 17:29:23 GMT 10
Hi guys, we're just contemplating a hot water setup for our campervan (is '73 old enough for me to call it vintage???) I want to add an outside shower in a recessed panel and have hot water at the kitchen sink ocassionally. A 12 volt pump, heat exchanger and small hot water header tank similar to a glind/ twine/ pirahna underbonnet shower setup used on 4wd's or is there a 12 volt imersion type heater that would be effective without having to run the truck and wake our neighbours?
Post by belinda on Jul 5, 2006 20:26:02 GMT 10
We used one of those black bag solar things on our Summer holiday and the water easily got far too hot for the kids to use without adding plenty of cold.
Heating up enough hot water for a shower takes a lot of energy, so if you can get at least part of it for free it's well worth while. Try to incorporate solar heating somewhere in the system - maybe pre-heating water before it goes through a heater and pump.
An insulated drum from a camping shop will store heated water the same as it does icy drinks, so you could store hot water while heating up a second batch.
Post by hwyman on Jul 6, 2006 16:41:34 GMT 10
Hi liam have you consided one of these not real cheap but look well made and practical . Brian ebay item -8813786138
Post by trodler on Jul 6, 2006 16:44:56 GMT 10
Hi Liam If you have a look in ebay under instantanious hot water you should find a couple of options.
A small electric instantanious water heater for around $200.00
Or a small instantanious LPG water heater for around $350.00
Not sure how well they work but im sure it would be OK for a shower on a warm night, and with this option you dont have to worry about water storage.
Cheers. Trodler.
Post by groovy on Jul 7, 2006 19:31:04 GMT 10
If you consider the instant gas water heaters on ebay, be careful and get a guarantee that it has the AGA approval certicate included. I have been told that they are not approved for use in either OZ or NZ, but that is heresay, hence the reason to check for AGA approval certificate. Greg
