Post by mytriumphcar on Jun 15, 2006 13:21:47 GMT 10
Has anyone put reflectors on their caravans? Other than the normal tail light ones. Any down the side etc
Regards Kathryn
Post by pcc on Jun 15, 2006 20:52:55 GMT 10
Neons maybe, but not sure on reflectors Why would you want them on the side. May be when the TC goes too fast round a corner and the caravan is sideways Now that would be cool
Post by mytriumphcar on Jun 16, 2006 11:02:13 GMT 10
The TC is called Bessie and I should look after her better! I never really think about how old Bessie is, 1975. I have had her since 1990. I was just thinking reflectors on the side of caravans just as a safety thing. Maybe thats just me and not really needed! Cheers Kathryn
Post by mytriumphcar on Jun 16, 2006 19:11:44 GMT 10
Hi Col Triumph 2500 TC automatic Cheers Kathryn
Post by humpty2 on Jun 16, 2006 20:02:53 GMT 10
Maybe you should check with road regulations first before you put any reflectors on the sides. White or amber facing forward, red facing rearwards, sides.??
Post by mytriumphcar on Jun 17, 2006 12:17:19 GMT 10
Hi Humpty2 From Qld transport regulations Trailers manufactured prior to 1 August 1989 must comply with the Transport Operations (Road Use Managementó Vehicle Standards & Safety) Regulation 1999. Lamps * 2 red brake lamps * * tail lamps or brake/ tail lamp combination * * direction indicator lamps * number plate lamp * a pair of red clearance lights fitted to the rear of the vehicle if the vehicle is at least 2.2 metres wide * 2 end marker lamps showing to the front and two lamps showing red to the rear must be fitted to a trailer more than 2.1 metres wide Reflectors * 2 front reflex reflectors - white * side reflectors - one per side - amber * 2 rear reflectors - Red * 1 brake lamp fitted to the centre or to the right of centre permitted if the trailer was manufactured prior to July 1973. * 1 tail light fitted on or towards the rear of the vehicle permitted if the trailer was manufactured prior to July 1973. I have put them on but was wondering if anyone else did. Cheers Kathryn
Jim
Post by Jim on Jun 18, 2006 10:32:07 GMT 10
Hi Kathryn This thread is almost dead but I’m back on my VSB-1 hobby horse again (It seems it’s my favourite) I know it’s not purist or absolutely authentic with an older van, but if you follow the current regulations you can’t go wrong in the eyes of the law or with making an effort to be seen on the road. Lights and reflector requirements depend on the size of a trailer or caravan. To find out what’s required click the link below. It’s the VSB-1 build guide (Vehicle Standards Bulletin-1). Check out section 9. It’s a national standard determined by the Dept of Transport and Regional Services. All states use this Standard. www.dotars.gov.au/transport/safety/road/bulletin/vsb1/index.aspxThe following sections deal with reflectors: 9.8.1 9.8.2 9.8.3
