Post by belinda on Mar 23, 2006 18:46:51 GMT 10
Doing a really original restoration?
campApack have a small quantity of ice box hinges and catches available.
Contack Glenda or Jiri at campapack@dodo.com.au
cheers
Belinda
Post by belinda on Dec 16, 2006 11:08:45 GMT 10
Jiri at Campapack has made a fabulous new waffle thingy for our ice box. Thanks so much to Maurie for lending us the one out of Doris - it's on its way back to you via registered mail. Why is this such a good copy? Because Jiri has the actual machine that made trays for Atlantic Caravans. Jiri made an extra tray at the same time and has it in stock, so if you need one contact Campapack (see details in first post on this thread). He can also make anything else you need, such as water tanks or ice box inserts. This is the new tray next to Maurie's original The ice tray fits over the hole in the ice box. Cold air drops down into the bottom compartment, but water runs to the back of the top shelf (which is slightly sloped) and down a drain hole.
Post by Roehm3108 on Dec 16, 2006 18:02:48 GMT 10
Thanks for the info Belinda - will remember this when I get around to building the fridge into the Superb. Cheers Ray
