Post by aussieute on Dec 25, 2016 14:15:45 GMT 10
this is what is left of the old hitch wanted to buy another or have this one refurbished thanks chris
Post by Rattles on Dec 25, 2016 17:50:49 GMT 10
Post by Franklin1 on Dec 26, 2016 22:36:56 GMT 10
G'day aussieute, Your coupling seems to be similar to the "Locktite" coupling used on John Walsh caravans. See this post in the "Old Tow Couplings" thread. The main difference with yours is the flat section on the top of the main coupling body, so it may not be an actual Locktite version. Can you see any evidence of a Patent number stamped on the side of the ball holder, usually where the pin is hammered through the spring-loaded shaft? cheers, Al.
Post by aussieute on Dec 27, 2016 12:28:23 GMT 10
Thanks rattles have bought one of these hitches but am hopping to get one like the original like Franklin 1 has posted as my hitch goes in between the steel frame and to put another kind on would mean altering the draw bar thanks for the help as now i know what i am looking for chris
Post by aussieute on Mar 24, 2017 8:13:52 GMT 10
Post by Rattles on Mar 24, 2017 9:25:51 GMT 10
You are only missing the handle/latch, Any chance of fabricating a new one or removing the one off the purchased new one (remove the C Pin), and either Drill/Shim the handle to suit the old Coupling and alter the spring loaded lock mechanism to suit.
Unless there is wear/Broken Part on the old coupling, a Strip down and clean/grease the original should be serviceable.
Rattles
Post by aussieute on Mar 24, 2017 11:22:46 GMT 10
The center shaft is very badly cratered and would need a new one to be machined I am hoping to find another if only it was only the handle thanks chris
Post by aussieute on Apr 14, 2017 12:23:16 GMT 10
Bump
Post by aussieute on May 5, 2017 12:40:36 GMT 10
Still looking for hitch
Post by aussieute on Aug 25, 2019 10:34:35 GMT 10
It's been a while but still looking for hitch thanks chris
Post by aussieute on Mar 5, 2021 14:54:23 GMT 10
Still need hitch if anyone can help thanks Chris
