Post by Jim on Apr 5, 2006 17:23:59 GMT 10
I’d be very reluctant to use a rockwool or glass fibre insulation in a teardrop or a van.
In fact I wouldn't.. but you do as you like.
Those products are ok in a building that doesn’t bump along the road now and then, but vibration could cause it to settle and cause small fibres to break off.
It seems glass fibre insulation may give a better ‘R’ rating for a given thickness than alternatives, but it’s itchy stuff and if any fibres happened to find their way out at some later time you could be in for a scratching good time.
Personally, I long ago got past being willing to even fit it in a ceiling.
Any problem in the walls or roof of a teardrop would be difficult to rectify after its all been put together.
Water resistant foil backed polystyrene panels are another choice or polyester insulation bats or blankets are another.
I’d guess polystyrene panels would insulate well but not give any acoustic advantage.
The cutting and fitting would be a fiddle and you would have to glue them in place.
Information here to find out about this product.
www.foilboard.com.au
(Click the Foil Board logo)
So that leaves polyester bats or blankets. These are probably the easiest to work with.
Tear them up, stuff them in, very stable and no itching.
The only downside seems to be that they melt at about 250°C.
They don’t add to the fuel load and if you were still inside at 250°C you’d be burnt toast anyway.
Information here..
www.solartex.com.au/view_article.asp?id=14&cat=4
Tontine make a 50mm blanket that would be ok, it will compress quite readily.
But where to buy it could be a problem as it’s more an industrial product
Info here..
www.tontinefibres.com.au/Data-Sheets/Insuloft-building-blanket.asp
Or you could simply buy 90mm polyester bats and split them down the centre. It wouldn’t be too big a job with a decent pair of scissors for the amount needed.
About $40.00 will buy enough polyester bats from Bunnings to do a couple of teardrops and still have some left over.
Information here..
Info here..
