Post by SM on Jan 12, 2006 13:58:11 GMT 10
PLeEASE...
Can anyone help me with a supplier of Rubber Extrusions for Caravan Windows. I have a 60's GlobeTrotter with perished Seals, some I have sourced others particularly those that run around the windows that open are a bugger to find... They feed into the Aluminium extrusion..
Any help would be greatly appreciated...thanks
...Mike
Post by WILL AND LYN on Jan 12, 2006 14:07:24 GMT 10
GIDDAY mike
check under technical on this forum and there is a place in Welshpool w.a. that may have a catalogue if you give them a ring
WILL
Post by humpty2 on Jan 12, 2006 18:37:01 GMT 10
If you are referring to the "Qualcraft" windows that open out from the top. I modified a section from 'Clarke Rubber'........I trimmed the sides in on the "T" section and used a loooooot of Vaseline and swear words to get the rubbers into the groove.......especially around the bends!!!!
Post by SM on Jan 13, 2006 14:01:07 GMT 10
[glow=TEAL,2,300]tHANKS GUYS... MUch APPRECIAteD[/glow]
