GLUE
Jun 14, 2005 12:09:06 GMT 10
Post by scootman on Jun 14, 2005 12:09:06 GMT 10
Hi all , am just getting to the stage of glueing my framing together, in particular the bent wood around the outside of the frame that needs to be laminated together. What do you reckon is the best glue for the job? Scoot
GLUE
Jun 15, 2005 20:36:09 GMT 10
Post by caraparker on Jun 15, 2005 20:36:09 GMT 10
I found that caravan joinery is very similar to boat fitting out and I can more than recomend west system epoxy with the requisite powered filler added to make the thickness of glue you require, the only thing is that it is not UV tolerent so it has to be covered with paint, ply, etc. It is available from any chandlery. Cheers
GLUE
Jun 15, 2005 23:19:26 GMT 10
Post by scootman on Jun 15, 2005 23:19:26 GMT 10
Thanks Cara will add that to my list of things to investigate.
