Post by Mustang on Mar 1, 2016 17:34:32 GMT 10
Classy, yes very classy reno, congratulations.
thomas
![*](//storage.proboards.com/forum/images/stars/star_black.png)
Post by thomas on May 15, 2016 13:58:34 GMT 10
Thx Mustang..!
Lots more has happened since this...will update soon.
thomas
Post by thomas on May 15, 2016 14:17:39 GMT 10
Gday Boomer,
Apologies - only just found your post!!
Yes - we added extra length & 'meat' to the draw bar. Should assist with maneuverability. Doing it again, i'd probably go a tad longer again, to add a decent size box. Correct though, got to cut down on weight somewhere.!
As for the windows, I purchased my Lexan type product from a local supplier. Its really light & cuts very easily & is around 3mm thick. Be careful, it seems to scratch really easy too. Even cleaning with out scratching seems to be an issue. I went for the plain stuff - no tint.
I reckon i'll go back to proper glass in the future, simply because I don't like the scratching.!
Regards,
T.
thomas
Post by thomas on May 29, 2016 14:57:47 GMT 10
Post by Mustang on May 29, 2016 16:32:11 GMT 10
Post by Rodnet on May 29, 2016 20:00:32 GMT 10
Well done
thomas
Post by thomas on Jun 19, 2016 21:44:24 GMT 10
thomas
Post by thomas on Jul 10, 2016 22:10:28 GMT 10
Hi all, All 12volt working!! ![](http://i72.photobucket.com/albums/i195/thebevis5/Mobile%20Uploads/image_zpsjxyko2gw.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/Mobile%20Uploads/image_zpskzhqvigm.jpeg)
Post by twocutekelpies on Aug 10, 2016 6:19:07 GMT 10
Hi Thomas, that's looking fantastic. I wonder if you could tell me what trim you used around your door frame please? I've just started on a '73 Ambassador and I think the original plastic frame might be near impossible to source and my original one shattered when I took it off. Cheers Shelley
thomas
Post by thomas on Aug 21, 2016 21:23:21 GMT 10
Hi Thomas, that's looking fantastic. I wonder if you could tell me what trim you used around your door frame please? I've just started on a '73 Ambassador and I think the original plastic frame might be near impossible to source and my original one shattered when I took it off. Cheers Shelley Hi Shelley, which door are you referring to?? Apologies for the late reply! rgds, C.
Post by twocutekelpies on Aug 22, 2016 6:51:19 GMT 10
No worries, it's the plastic frame around the main door. Sorry only just worked out how to post a photo. IMG_6778
thomas
Post by thomas on Aug 27, 2016 17:54:46 GMT 10
Tough one....
Mine is metal, but you should be able to locate something suitable as a replacement.
If you can't find plastic, might be worth while getting some metal trims folded up.
Rgds, T.
