thomas
![*](//storage.proboards.com/forum/images/stars/star_black.png)
Post by thomas on Nov 2, 2014 8:32:40 GMT 10
Thx HB - i will look into that product to see If i can source in Tassie.
Rgds, T.
Post by murray on Nov 2, 2014 18:23:01 GMT 10
![](http://s72.photobucket.com/user/thebevis5/media/IMG-20130713-00248_zps42dc9df4.jpg.html) ![]() ![Lenny](http://i72.photobucket.com/albums/i195/thebevis5/IMG-20130713-00248_zps42dc9df4.jpg) Thomas, What was the caravan next to yours? Are you north or south tassie? Cheers Murray
thomas
Post by thomas on Nov 3, 2014 19:22:58 GMT 10
Hey Murray,
Unsure on that....looks to be maybe another Viscount, early 60's maybe..?? I do have another photo of that van which shows the side profile better, but the location of that photo eludes myself at this point.! I will keep digging & upload if I find it.
I believe that she's still in that same location too..!
I'm located in North Tassie...!
Rgds, T.
Post by murray on Nov 3, 2014 19:33:56 GMT 10
Cheers Thomas. Another member in Tassie - the VV state Those 2018 nationals in Tassie are looking good ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) cheers Murray
thomas
Post by thomas on Nov 13, 2014 16:54:45 GMT 10
thomas
Post by thomas on Nov 13, 2014 16:57:07 GMT 10
Cheers Thomas. Another member in Tassie - the VV state Those 2018 nationals in Tassie are looking good ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) cheers Murray That would be sweet..! T.
Post by Observatory on Nov 13, 2014 20:02:45 GMT 10
Hey Thomas,
Your doing a nice tidy job there.. keep it up!
Pete
thomas
Post by thomas on Jan 25, 2015 12:19:18 GMT 10
Post by mibosa on Jan 25, 2015 16:46:00 GMT 10
Hi Thomas, could you please advise what product you used to do the strip caulking?
Regards, Bob.
Post by akeepsake on Jan 25, 2015 21:21:52 GMT 10
Cheers Thomas. Another member in Tassie - the VV state Those 2018 nationals in Tassie are looking good ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) cheers Murray That would be sweet..! T. Great job you're doing there Thomas You've slipped under my radar till now but as Murray said 2018 for nationals looking good! I'm in Ulverstone r u close by? Cheers Andrew
thomas
Post by thomas on Jan 26, 2015 20:13:37 GMT 10
Hi Andrew,
I'm located in Launceston, but travel the state for work - from Huonville in the south to Burnie in the north. Thx for the comments!!
Looking forward to start working on the inside.!
Rgds, T.
thomas
Post by thomas on Jan 26, 2015 20:21:42 GMT 10
Hi Thomas, could you please advise what product you used to do the strip caulking? Regards, Bob. Hi Bob, Head to the CaravansPlus website - $9.65 a role.! I sourced mine locally & have used it for all the windows, tail & running lights, power inlet, external light & all the edge stripping.! Really easy to use & its what they used originally. Extra bonus is if you ever have to remove a window, you wont ruin it trying to get it out, unlike silicone..! Rgds, T.
Post by mibosa on Jan 27, 2015 7:33:31 GMT 10
Thanks Thomas,
Regards, Bob
Post by murray on Jan 27, 2015 8:11:28 GMT 10
Hi Andrew, I'm located in Launceston, but travel the state for work - from Huonville in the south to Burnie in the north. Thx for the comments!! Looking forward to start working on the inside.! Rgds, T. Hey Akeepsake, looks like we have a north-south delivery service ![::)](//storage.proboards.com/forum/images/smiley/eyesroll.png) Cheers Murray
thomas
Post by thomas on Jan 27, 2015 19:14:39 GMT 10
Hey murray,
I have no issues with that ...! Happy to help out fellow VV'ers...!☺
Sing out if you need something transported.....I drive a Mondeo Wagon...!!
Rgds,
T.
thomas
Post by thomas on Jul 5, 2015 15:41:08 GMT 10
Hi all, Well - I've had the young fella on the job recently....running some flex core & also doing some soldering.! Some other pics of the outside works attached as well. Progress is slow due to time at present, & also trying to trace a couple of very annoying leaks.! Hopefully, I've now got those sorted & it's to the inside we go.! Still have to sort out some wheels & some simple graphics for the sides. Rgds, T. ![Flex](http://i72.photobucket.com/albums/i195/thebevis5/_MG_5159_R_zpsdtjsyc5g.jpg) ![Running flex core](http://i72.photobucket.com/albums/i195/thebevis5/_MG_5158_R_zpszffnlfe4.jpg) ![Running flex](http://i72.photobucket.com/albums/i195/thebevis5/_MG_5144_zpsubli6n50.jpg) ![Outside](http://i72.photobucket.com/albums/i195/thebevis5/_MG_4983_R_zpsycu1eob2.jpg) ![Outside](http://i72.photobucket.com/albums/i195/thebevis5/_MG_4982_R_zpsckuyfqzy.jpg) ![Outside](http://i72.photobucket.com/albums/i195/thebevis5/_MG_4973_R_zpsndiuuxhj.jpg)
Post by Rattles on Jul 5, 2015 16:54:22 GMT 10
Thomas - If you have not already run in earth wires to each lamp, It is a better choice when running in the wiring for the Stop/Tail/Blinkers/Clearance lights run in an Earth return wire (-ve) to each light fitting (Daisy chain connection is ok) so as not to rely on the unreliable Aluminium Frame/Skin of the Caravan. Connect all Negative (Earths) wires at both ends of trailer connector (Car and Caravan) and Anderson Plug if used.
Note the 240v Earth wire should have its own Earth connection to the Caravan Frame/Chassis and not share the 12v Negative connection.
Rattles
thomas
Post by thomas on Jul 5, 2015 21:07:48 GMT 10
Gday Rattles,
Yep - all lights have seperate earths....all connected to main earth back at the trailer plug. All works beautifully. No way i was going to rely on the old system..!
Rgds, T.
Post by Observatory on Jul 8, 2015 10:42:21 GMT 10
Lookin good Thomas, nice way to find leaks while all the inside is stripped out - saves having water seeping into the cabinetry and timber. The outer looks immaculate! A credit to you.
Pete
thomas
Post by thomas on Jul 9, 2015 21:40:33 GMT 10
Thx Pete - appreciate the kind comments. Looking forward to starting the prep work inside & getting some insulation into it.!
Rgds,
T.
thomas
Post by thomas on Oct 10, 2015 20:50:54 GMT 10
Hi all, Progress of late: - new wheels / fully insulated / front and rear end ply fitted. Electrician will be in shortly, then its onto the 12 volt system wiring and wall panelling. Rgds, T. ![](http://i72.photobucket.com/albums/i195/thebevis5/Mobile%20Uploads/image_zpswwgu8hnb.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/Mobile%20Uploads/image_zpsumrbg1id.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/Mobile%20Uploads/image_zpsauwz4my6.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/Mobile%20Uploads/image_zpsgiflinrc.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/Mobile%20Uploads/image_zpsohetofqz.jpg)
thomas
Post by thomas on Dec 6, 2015 9:17:06 GMT 10
Hi all, Lots of wiring at present....think i've about got it covered for the 12 / 240 volt. Speaker wire & coax to go. Hoping to get some lining done over the xmas break.!! Tested my new Narva touch lights last night - pls excuse the crude lighting plan!!!. I think they add ample light & are wired on three separate circuits. Regards, T. ![](http://i72.photobucket.com/albums/i195/thebevis5/IMG_1001_zps1fatcvva.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/IMG_0999_zpsm5tcwsuy.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/IMG_0998_zpsaw8ohuoc.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/IMG_0996_zpsrv1jz7uw.jpg)
thomas
Post by thomas on Jan 10, 2016 20:25:32 GMT 10
Hi all, Well - some steady progress over the Xmas Break. Broke for holidays on the 18th December & post xmas, had a few solid days working on the Viscount before heading back to work on the 4th of January . Work completed: - all 12 / 240 volt wiring completed - internal paneling completed, including the ceiling & installing of the LED lights: :- Ceiling is Embossed White :- Walls are Polyester Gloss White Just need to finalize the trimming around the windows, fit their cover strips & edge around the Hatch & it will be onto the cupboards.! Have attached pics as always..! Rgds, T. ![](http://i72.photobucket.com/albums/i195/thebevis5/image_zpsbuxdwikt.jpeg) ![](http://i72.photobucket.com/albums/i195/thebevis5/IMG_1367_zps0fsozycw.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/IMG_1393_zpskfalheow.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/IMG_1394_zps46qdgobk.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/IMG_1396_zpsbijbyu0t.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/IMG_1405_zpsl5y2cfv0.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/IMG_1409_zps1nfq4nz4.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/IMG_1417_zpsughokwrn.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/IMG_1427_zpsaqmk8lay.jpg)
thomas
Post by thomas on Feb 14, 2016 21:05:13 GMT 10
Hi all, Progress of late. All windows & hatch trimmed, 12 volt lighting panels fabricated & installed, rear, side & front overhead cupboards framed & installed & ready for lining next weekend! Pics below. Rgds, T. ![](http://i72.photobucket.com/albums/i195/thebevis5/Mobile%20Uploads/IMG_1701_zpsvp3nyjvq.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/Mobile%20Uploads/IMG_1706_zpssalpfsgg.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/Mobile%20Uploads/IMG_1707_zps3nquf8rh.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/Mobile%20Uploads/IMG_1712_zpsszbhpktd.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/Mobile%20Uploads/IMG_1710_zpspvfvd8ti.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/IMG_1625_zps5qeslacv.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/IMG_1619_zpst6jvlcbj.jpg) ![](http://i72.photobucket.com/albums/i195/thebevis5/IMG_1578_zpskbk8l5ne.jpg)
Post by boomer54 on Feb 29, 2016 19:37:52 GMT 10
Hi there Thomas Just read your thread on a frame and windows. I see you added 300mm to your draw bar on the caravan, I' m thinking of adding 500mm to my draw bar. I was thinking of adding a tool box but I don't think I have the room and the a frame will have to much weight. Also with your lexan windows did you go for tinted or plain? Where did you get your lexan from and what thickness did you get? Regards David
