Post by humpty2 on May 15, 2012 17:08:23 GMT 10
Post by Franklin1 on May 15, 2012 19:40:17 GMT 10
G'day humpty, Well, that's not what I thought you had in your PM to me! ![:o](//storage.proboards.com/forum/images/smiley/shocked.png) I reckon you'll need to go back to a time between 1958 and 1960 for this one. Here is its cousin... ![](http://i42.photobucket.com/albums/e345/macola51/Millard%20Caravans/1961Millardnearside.jpg) ![](http://i42.photobucket.com/albums/e345/macola51/Millard%20Caravans/1961Millardfront.jpg) I did ask the seller of that van at the time whether it had a chassis number, and he couldn't find anything, so I think these vans are from before the introduction of the Millard chassis numbering system. The earliest Millard chassis number I've got is M1125, which was claimed to be a 1962 model, and it certainly appears to be from that time period... ![](http://i42.photobucket.com/albums/e345/macola51/Millard%20Caravans/1962M1125Millardfrontandlogo.jpg) Are the sides on your van made of ply or aluminium, and what is the length of the cabin along that cover strip sitting below the side windows? cheers, Al.
Post by humpty2 on May 15, 2012 19:56:03 GMT 10
The cladding is all diamond pattern flat Aluminium. I do have the wheel spats too....well the aluminium minus the wood ![::)](//storage.proboards.com/forum/images/smiley/eyesroll.png) Have yet to find out if the fridge works........they usually don't ![:(](//storage.proboards.com/forum/images/smiley/sad.png)
Post by Rattles on May 15, 2012 21:25:50 GMT 10
This may help it not the same Fridge but hopefully point you in the right direction.
If you require a higher resolution copy PM me with your E-Mail address and I will send it to you.
Rattles
Post by streets on May 11, 2023 18:48:35 GMT 10
Hey there me too wondering what the one I want to register is. No paperwork? You think will pass rego? Millard - M49298’ we have no idea what model this is and the roads and traffic gave me the weirdest look today to get a permit to move? Any idea where the chassis number is also, to get this permit
Post by Roehm3108 on May 23, 2023 15:13:00 GMT 10
This is an old thread. We really can't answer the questions you pose about passing rego. You need to work with them and they will help. If you want more ID info, you need to put up a photo or two.
Post by Don Ricardo on May 25, 2023 15:13:27 GMT 10
Hi Streets,
Roehm3108 is correct in what he says, but I can add that the number you quoted of 'M49298' is the serial number or chassis number of your caravan. I've checked on the Millard register compiled by another member of this Forum, Twocutekelpies, and that serial number indicates that your van was built in 1976.
Generally speaking, it is perfectly possible to get an older van registered, but as Roehm3108 has suggested talk to the rego authorities about what they require. There are plenty of vintage vans registered, some built as far back as the very early 1930's, so a 1976 caravan is just a youngster! Obviously it needs to be in a good safe condition.
Good luck.
