Post by takeiteasy on Mar 4, 2012 20:04:18 GMT 10
I was thinking what would make a good strong bed base, was light, and let a lot of air around the mattress. I thought security screen might fit the bill. Has anyone tried it.
Yes I know it isn't true to the period.
Post by takeiteasy on Mar 5, 2012 12:13:16 GMT 10
OK, no one has tried it. Can anyone see why it wouldn't work?
Post by greedy53 on Mar 5, 2012 17:57:47 GMT 10
depends how much weight it will carry could be a bad night if weights are wrong my self i have just finished my bed i used 1x2 inch slates 3 inches apart than a sheet of pegboard for a bit of air circulation
Post by Deleted on Mar 5, 2012 18:09:22 GMT 10
Security screen for bed base....... coooool,..... Well...... at least ya could sleep tight knowing that no one is going to break into your bed from underneath .... That'll keep the burglars out.... ;D Reddo
Post by takeiteasy on Mar 5, 2012 18:16:24 GMT 10
Greedy, I suppose slats wouldn't be that much heavier. I know the good stuff won't sag but I haven't priced it. It may be expensive.
Reddo, I like to know my arse is secure.
Post by bubbles on Mar 8, 2012 23:57:11 GMT 10
Security screen ooh made of ali and when ali stretches or bends it wont return to original shape I would stick to wooden slats
Post by Rattles on Mar 9, 2012 9:36:10 GMT 10
Cant think of a reason to knock the Idea. However If it's used as a Trampoline and in the design of the base a cross support at were your hips are and a perimeter frame should be enough support. This is where my Caravan bed has a cross brace and perimeter support the ply slat trampoline base. The Bed base in my van is only 25mm x 25mm pine and 3mm ply very simple with minimal weight and has never broken in 12 years.
Post by greedy53 on Mar 9, 2012 17:24:34 GMT 10
the slates were the cheap ones but i had framing every 18 inches that acted like legs i'm a little on the robust side of 100 kgs and have no worries
Post by takeiteasy on Mar 9, 2012 17:32:54 GMT 10
Thanks bubbles, rattles, and greedy (where but on the 'net would I write that intro). I am trying to keep weight in mind as the van seems quite heavy already.
