Post by hilldweller on Feb 26, 2012 16:48:58 GMT 10
Hello all - I'm stuck again Getting close - I hope - to being able to put some wall linings on ;D and thinking before I do so I had better have a plan for the dinette table. Am I right in thinking I need to put a reasonably solid rail along the front wall of the van before covering it with the 4mm ply, so there's something fairly solid to attach the table to? And then what do I do? Table needs to be detachable so it can be used as bed base. What sort of hardware fittings do I use to attach/detach it from the wall? And then there's the leg.... Having bought two old tables to get enough formica for table and kitchen benchtop, I now have eight chrome legs, and am wondering if one of those could be made into a folding leg for the table. Both tables have the same style of leg - a long skinny U shape with the two open ends of tube (20mm diameter or thereabouts) at the top. Any ideas on how I could mount one of those so it can be folded under? Table will be small, if that matters - about 600 x 850 - because that's the length of formica I have
Post by humpty2 on Feb 28, 2012 19:08:36 GMT 10
I used marconi track to attach/secure, and be able to remove my table.
Post by Roehm3108 on Feb 28, 2012 20:15:13 GMT 10
Post by Jennison on Feb 28, 2012 21:00:49 GMT 10
A small length of Marconi track along the outside of you van and you can also set it up under the annex as well for eating outside jenno
