Post by webrake4bricabrac on Feb 6, 2012 11:31:46 GMT 10
This is a bit of a long shot - but does anyone have a spare one of these? My 1959 Coronet is fitted with a gas lamp and two types of electric lighting. Of the two electric lamps, I do not know which is older and why they are doubled up. Perhaps the fluoro is original and the round lamps were added later for their softer light. Any other suggestions? (I see one of the round lamps just sold on eb*y for $60.)
Post by DC3Td on Feb 6, 2012 14:41:58 GMT 10
Hi Webrake. Are they both of the same voltage or 12V & 240V? gordon
Post by webrake4bricabrac on Feb 7, 2012 13:07:24 GMT 10
Hmmm, good question . I'm not keen to connect the mains supply until I've had the wiring checked, but will see if I can figure it out.
nomad
Post by nomad on Feb 8, 2012 22:34:05 GMT 10
The strip light is a fairly common bathroom type of late fifties through to early seventies vintage, it has a 240v incandesent filament type globe, they turned up on bathroom mirrors and you can probably still get them from specialty globe suppliers. I'd reckon the round clipper type would probably be the 12volt unit. I'd be careful of that taped up wire end, if you're not going to get another strip in the near future a miniature junction box from the big hardware chain is probably very cheap insurance against burning yourself or the van to the ground.
nomad
Post by nomad on Feb 8, 2012 22:35:19 GMT 10
GMT Globes in Hawthorn can probably help.
Post by coronet10 on Aug 4, 2012 0:32:56 GMT 10
hi our coronet (ivanhoe) has the same type light it is a globe not a fluro is the round light 240v or 12v also have the same gas light and roof pattern frank
Post by webrake4bricabrac on Aug 6, 2012 0:04:27 GMT 10
Turns out the long lamps are 240V and the round lamps are 12V.
For the time being, I have disconnected the 240V lamps rather than converting to dual pole switches.
I can always use a portable lamp through the dual pole GPO I have had installed.
Post by destrier on Aug 10, 2012 22:34:29 GMT 10
Hi there Webrake4bricabrac, I think I may have a spare one. Will let you know tomorrow evening. Destrier
