curly
Post by curly on Jul 29, 2011 15:58:48 GMT 10
Can anyone tell me what the best glue or urithane is for sticking alloy sheets to steel frames.Does the steel need to be painted first and with what.
Post by overlanda on Jul 29, 2011 19:39:53 GMT 10
Hi Curly We normally use a Wurth product called KD Bond and Seal which is a urethane product Sika have a similar product which is available from Bunnings. You should read the instructions with the product to see if it needs to be primed or any other instructions . You can also use a neutral silicone in some situations. Regards Gerald
curly
Post by curly on Jul 30, 2011 18:26:37 GMT 10
Great,thanks for that "overlander", aint this a cooool site.Curly.
