Post by surferh on Apr 10, 2011 19:26:35 GMT 10
what can i use for an internal window arcitrave? as the corners are round... what has everyone else used? thanks
Post by frankidownunder on Apr 10, 2011 21:33:17 GMT 10
Post by surferh on Apr 11, 2011 18:39:48 GMT 10
how did you get the corners done? does it bend that much?
Post by frankidownunder on Apr 13, 2011 21:42:08 GMT 10
The trim material is quite flexible, I bent it around the bottom window corners which are about 50mm radius without any trouble.The top corners are right angle so I just mitre joined to the top trim. PVC material can be bent quite tightly if gently heated first with a hair dryer or heat gun set on very low temperature, you just need to experiment first with a scrap piece to get temperature and bend right before tackling the main job.
