Post by overlanda on Apr 9, 2011 19:06:52 GMT 10
Looking at the pictures on your restoration i would just replace the 3 sheets of ally as it will be cheaper and a lot less pain than trying to strip the polyester resin off. If you want i can get some sheets in and cut them to size lock seam them so you don't get all the screw holes to seal . Of memory it works out at about $ 52.00 a sheet for stipple finish silver in 8x4 sheets. let me know if you want to go down that path. Regards Gerald
