Post by curtis on Feb 7, 2011 15:39:19 GMT 10
Hey Dave,
I would suggest you would need a BIG ass welder to put a stub axle back on, normal arc (240 volt - 3.0mm rods) would just not penetrate deep enough I reckon. At least I would seek some professional advice.
What is the width of your Wayfarer?? You say it is a 4 or 5" drop??
Dave
Post by kaybee on Feb 7, 2011 15:40:19 GMT 10
Hiya Dave,stick a photo on....might be something that can be repaired if it's right up at the end......if not,you can get a new axle made to whatever dimension you want ......regards, Col.
Post by kaybee on Feb 7, 2011 16:50:04 GMT 10
Hiya ..a bit hard to tell how much is axle damage and how much is smeared nut.......you're probably going to have to try and separate the nut remnant from the axle to see if it's saveable......a couple of careful cuts with a 1mm disc and a smack with a sharp cold chisel should split the nut away from the threaded end......if the thread can be re-cut and the end squared off ,you may be able to machine the outer bearing recess to move the bearing inboard a little to give you a bit more thread for a new nut....but it's a bit of foolin' around,especially if you have to rely on others to do machine work,etc.......so it's probably going to be more cost effective to shop around for a new axle and then you can have it drilled to whatever wheel pattern ,width and drop that you want. There's a few trailer manufacturers up this way in Bayswater if you can't find anyone closer.......do a bit of phoning around once you have some measurements to give them......cheers.....
Post by kaybee on Feb 7, 2011 19:21:55 GMT 10
G'day Dave, no.....they aren't removable. If the stub axle can't be saved ,then it's time for a whole axle. It isn't really a big deal,you should be able to take your whole axle and hubs to a trailer/caravan supplier and have one reproduced to the same spec....including the locater. Might take a bit of shopping around to find the right place, not so much a retailer as a manufacturer....so that the guy you are dealing with is the guy who builds the part.....saves time and avoids stuff ups through miscommunication.....happy hunting ;D
Post by firefighter on Feb 7, 2011 20:11:41 GMT 10
Post by sportsman 1 on Feb 8, 2011 7:47:36 GMT 10
Dave,
what is the width of the axle? I have a drop axle here which I am not using. I would be happy to come over and help you with it to get you going at least to get it to WP.
Ring me at work on 9877 0666 or home 97354606 after 9.00pm
Leigh.
Post by kaybee on Feb 9, 2011 12:07:30 GMT 10
....see?.....told ya it shouldn't be a problem,and there's you getting all worked up over nothing..... ;D ;D, glad to hear you're back on track again....cheers, Col.
Post by kaybee on Feb 12, 2011 14:45:41 GMT 10
G'day O/F.....how come you didn't get a drop axle for it?.....
Post by JBJ on Feb 12, 2011 16:25:50 GMT 10
Hi Dave,
Hope you welded the saddles onto the axles, cause if you didnt they will slide around, no matter how much you tighten the U-bolts.
Just an observation cause I didnt see anything to indicate you had
Those straight axles are much cheaper than dropped axles, & if they are rated OK & do the job, I guess they are OK.
