Post by kustombruce on Aug 1, 2010 9:01:45 GMT 10
All Help needed I have purchased some old stabiliser bars for the Hawthorn, is there a specific distance the hooks should be along the A frame ?
The Hawthorn A frame is made of angle, not a box section, so I will have to modify the brackets or drill the A frame to bolt the hooks on to it.
I just want to get it right
Bruce
Post by cobber on Aug 1, 2010 10:34:30 GMT 10
G'day Bruce, This brochure was posted on the forum back in 2005 when this issue was raised.... lots of good info there. I think you should put a block in your angle iron behind the clamps rather than drill holes in it. Cobber.
Post by kustombruce on Aug 1, 2010 17:45:52 GMT 10
Thanks, that is the info I needed. I will work out a way of mounting without drilling holes, behind the angle is a 10 mm square bar reinforcement rod which will add to the level of difficulty
Bruce Bruce
