e38e49
27 ft carapark
Post by e38e49 on May 19, 2010 12:55:43 GMT 10
Hi, i need some windows for my (Carapark Astonaut) doe`s anyone know of someone that will custom make windows for a caravan, Cheer`s Harold
Post by humpty2 on May 19, 2010 17:45:03 GMT 10
are they the slopey ones....if so what are the dimensions.....and where the B$^$#y hell are you?
e38e49
27 ft carapark
Post by e38e49 on May 20, 2010 13:23:52 GMT 10
Hi Humpty2, the front window slopes at the front & is strait at the back, the measurements are 35 1/2" ins at the top & 33 1/4" ins at the bottom X 23 1/2 ins top to bottom, the back window slopes on both sides it is 42" ins wide X 23 1/2" ins top to bottom, these measurements are a rough estimate only as the actual frame that holds the glass is the piece that is missing, but the frame that is still in the van is a bit wider. i am located near Mittagong, i see your located in Newcastle the home of the Carapark, who now`s maybe there`s still some windows floating around Newcastle, i was actually born in Newcastle but left the in 1958,
Hope you can help, Thank you. Cheer`s Harold.
